rubber in the rear pop windows
https://www.ausmini.com/forums/viewtopic.php?f=2&t=26965
Author:  dale 62 [ Sat Jan 20, 2007 9:41 am ]
Post subject:  rubber in the rear pop windows
hey i am after where i can get the rubber inside the channel of chrome work where the pop window sits in thanks
Author:  mad-mk1 [ Sat Jan 20, 2007 10:36 am ]
hey man
do you have the original??
i would try
minisport or clark rubber
Author:  dale 62 [ Sat Jan 20, 2007 11:27 am ]
yeah i have the original its stuffd i rang minisport and they said they dont touch that
and clark rubber gave me a couple samples im not sure which one to get though.. and i already wasted 25 bux on the wrong one and i dont intend on getting the wrong one again :? thanks
Author:  boho [ Sat Jan 20, 2007 11:55 am ]
Lost your glass, have you Dale? When my rear passenger window was smashed with a brick it turned out cheaper and easier to replace the whole window. (It's four screws to get in and out). Mine's a Rover and Brickworx in SA helped me out nearly overnight. :)
Hope that helps.
Author:  drmini in aust [ Sat Jan 20, 2007 12:00 pm ]
There are so many s/h rear side windows about in good nick, just change em. :wink:
All Oz ones are the same Mk1 type, from `61 850 to `78 LS.
Author:  Clubbie74 [ Sat Jan 20, 2007 12:10 pm ]
They come up on ebay every couple of months or try the wanted section.
http://cgi.ebay.com.au/LEYLAND-MINI-REA ... dZViewItem
In Melbourne If you feel like a drive.
Author:  dale 62 [ Sat Jan 20, 2007 12:31 pm ]
thanks guy i have the glass i just saw the old rubber was stuffed and instead of me checking out the window i couldnt use i ruined my chances on using my good one 2 by taking it apart
Author:  rampage101 [ Sat Jan 20, 2007 2:34 pm ]
I also need the rubber only, as I'm a window tinter by trade now I pulled the glass completely out to get a perfect finish (although the glass is scratched and has overspray and grinding splatter :roll: ) because the rubber hold dust and it gets sucked up into the tint. My rubber was really shagged anyway, so can you get it? Or do i just need to make my own?
