It is currently Tue Jul 22, 2025 8:17 pm
PostPosted: Sat Jan 20, 2007 9:41 am
hey i am after where i can get the rubber inside the channel of chrome work where the pop window sits in thanks
PostPosted: Sat Jan 20, 2007 10:36 am
hey man
do you have the original??
i would try
minisport or clark rubber
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Sat Jan 20, 2007 11:27 am
yeah i have the original its stuffd i rang minisport and they said they dont touch that
and clark rubber gave me a couple samples im not sure which one to get though.. and i already wasted 25 bux on the wrong one and i dont intend on getting the wrong one again :? thanks
PostPosted: Sat Jan 20, 2007 11:55 am
I want to have Al's babies
Lost your glass, have you Dale? When my rear passenger window was smashed with a brick it turned out cheaper and easier to replace the whole window. (It's four screws to get in and out). Mine's a Rover and Brickworx in SA helped me out nearly overnight. :)
Hope that helps.
PostPosted: Sat Jan 20, 2007 12:00 pm
There are so many s/h rear side windows about in good nick, just change em. :wink:
All Oz ones are the same Mk1 type, from `61 850 to `78 LS.
PostPosted: Sat Jan 20, 2007 12:10 pm
They come up on ebay every couple of months or try the wanted section.
http://cgi.ebay.com.au/LEYLAND-MINI-REA ... dZViewItem
In Melbourne If you feel like a drive.
PostPosted: Sat Jan 20, 2007 12:31 pm
thanks guy i have the glass i just saw the old rubber was stuffed and instead of me checking out the window i couldnt use i ruined my chances on using my good one 2 by taking it apart
PostPosted: Sat Jan 20, 2007 2:34 pm
I also need the rubber only, as I'm a window tinter by trade now I pulled the glass completely out to get a perfect finish (although the glass is scratched and has overspray and grinding splatter :roll: ) because the rubber hold dust and it gets sucked up into the tint. My rubber was really shagged anyway, so can you get it? Or do i just need to make my own?
