Hi all,
The Holden dealer here in Cobram used to import Minis so I approached them in regards to pumping up my hydro.
They kindly offered to charge me 85 dollars for an hours labour, and I had to supply the fluid.... well, I am not going to do that, so, I made myself a pump from the grease gun idea I have read about here.
It was a piece of cake. I have pics of the setup if any of you want to have a go at it. Basically, I got a metre and a half of 1/4 hydraulic hose, various fittings to suit, and an air line fitting, female, to clip onto the male fitting on the valves.
The local tyre place has these types of air fittings, they are designed to allow a hose to be put onto it to fill tractor tyres with water, and allow the air to escape through the fitting. Cheap as hell to buy, and I have two, which will be permanently fitted to the car for future use. I picked this fitting mainly because I can just clip the line onto it, and not have to find the thread and turn the whole unit like the last one I borrowed, plus the whole thing cost me 47 bucks to make.
Just thought I would show any interested parties, and I am happy to build more for those who want one. I chose 1/4 BSP threads as they are common if I intend to upgrade it and fit a guage. Quite simple and about half an hour to create.
