Bonnet Hinges for Roundnose
https://www.ausmini.com/forums/viewtopic.php?f=2&t=27120
Author:  Mike [ Wed Jan 24, 2007 3:49 am ]
Post subject:  Bonnet Hinges for Roundnose
Is it possible to replace the threaded mounts on the bonnet hinges or is the whole hinge to be replaced?
Will the UK quick release ones fit?
Anyone wants to sell me a pair of bonnet hinges in good nick?
Author:  miniobsessed [ Wed Jan 24, 2007 4:24 am ]
You should find if you reach your hand up under the scuttle panel, where the threaded bracket pivots, there's a bolt that it pivots on. This can be undone with a couple of 7/16th spanners :)
Not sure about the fitment of UK ones...
Author:  drmini in aust [ Wed Jan 24, 2007 5:55 am ]
Mike is talking about the `studs' on the end where the bonnet attaches.
They are really a special headed bolt projection welded to the arm.
They can be ground off, the arm drilled out, and stud replaced by a bolt (preferably a grade 5 or better). This can be brazed or welded in- with a proper job done it can look pretty original. :wink:
Author:  Lillee [ Wed Jan 24, 2007 8:01 am ]
I had this precise problem. Take to them with a bench grinder and grind off the welded head bit and knock them out with a pin punch or the like. Then just use nut and bolt. If you are clever you can weld a new nut again
Author:  Mike [ Fri Jan 26, 2007 1:39 am ]
Thanks guys.
What about the minispares quick release hinges, would they fit the aussie roundnose bonnet?
Author:  miniobsessed [ Fri Jan 26, 2007 1:52 am ]
Doesn't look like it... They say for MK III onwards where the hinges are mounted further apart.
Author:  mad-mk1 [ Fri Jan 26, 2007 9:45 am ]
ill have a look, i have a set i took off my roundie
a bit later and let u know
Author:  Mike [ Sat Jan 27, 2007 6:34 am ]
I would appreciate this very very much
Author:  Mike [ Tue Feb 20, 2007 5:46 am ]
Fixed it ages ago but forgot to update. I just pressed the studs out with a vice, enlarged the holes with a drill, cleaned and repainted the hinges and refitted with 1/4in UNF high tensile bolts.
Works fine. Thanks for your help.
