2 Questions (with pics) https://www.ausmini.com/forums/viewtopic.php?f=2&t=27179 |
Author: | Jaffas [ Thu Jan 25, 2007 10:46 am ] |
Post subject: | 2 Questions (with pics) |
Just a couple more questions while I remember... There is a little knob on the drivers side, below and to the right of the steering wheel. It has a P and an arrow pointing right on it (see pic). Can anyone tell me what it's for? It doesn't appear to do anything when turned. ![]() Also.. we have an annoying problem with our windscreen wipers. RARELY we can get them back to a nice finishing position, even though the finishing position has been adjusted by pulling them off, and putting them on in the right position. We were told the brass washer inside the mechanism is worn. Does anyone know where to get new ones, what they're called or what they look like? I'd love to have this fixed by the time the rains come! ![]() Excuse the state of the mini, it needs some interior lovin'. ![]() Manda & Marty |
Author: | ryan [ Thu Jan 25, 2007 10:49 am ] |
the Knob looks like it could be a bonnet release, but i'm not certain. What comes out the back of it, and can you pull it out, like a choke. |
Author: | Jaffas [ Thu Jan 25, 2007 10:53 am ] |
The choke is on the left of the steering wheel, so it's not that. ![]() ![]() Other ideas? ![]() |
Author: | poeee [ Thu Jan 25, 2007 10:54 am ] |
The P knob is your dash panel brightness switch. |
Author: | ryan [ Thu Jan 25, 2007 10:55 am ] |
These are stabs in the dark but it could be a dimmer for a light, or possibly a varible speed control for wippers. |
Author: | Jaffas [ Thu Jan 25, 2007 11:48 am ] |
poeee wrote: The P knob is your dash panel brightness switch.
There are dash panel lights? ![]() ![]() I didn't question it too much, it's a 76, perhaps they hadn't thought of that by then, since there aren't any reverse lights either! ![]() Taking that apart will be fun, too! ![]() |
Author: | czerial [ Thu Jan 25, 2007 11:58 am ] |
yupppo Scots on the money, It dims or brightens (or turns off) your instrument cluster lights |
Author: | harvey69 [ Thu Jan 25, 2007 12:16 pm ] |
and thanks to mr lucas they dont always work ![]() |
Author: | Marvin [ Thu Jan 25, 2007 12:23 pm ] |
Found the horn yet? |
Author: | Jaffas [ Thu Jan 25, 2007 2:18 pm ] |
Marvin wrote: Found the horn yet?
Horn and I are well acquainted, thank you. ![]() ![]() |
Author: | clubmn [ Thu Jan 25, 2007 4:15 pm ] |
Post subject: | mm1275 |
As for parking the wipers, the arms have prob been removed at some time and fitted in an incorrect position, So simply remove both arms, Find the reverse point (TDC) on the wiper pivot and refit the arms. SIMPLE. |
Author: | CPOCSM [ Thu Jan 25, 2007 5:58 pm ] |
it is a potentiometer - lmao Yes it is a dimmer for your lights - also turns them off when you turn them all the way CCW(or was it CW????) Hooroo |
Author: | WhoDat [ Thu Jan 25, 2007 6:00 pm ] |
Jaffas wrote: poeee wrote: The P knob is your dash panel brightness switch. There are dash panel lights? ![]() ![]() I didn't question it too much, it's a 76, perhaps they hadn't thought of that by then, since there aren't any reverse lights either! ![]() Taking that apart will be fun, too! ![]() This is not turning on the dash lights [that is done at the headlights switch], but adjusting the brightness of them by rotating this knob in the direction of the arrow and back. At one end is full power to the globes at the other end of the sweep is no power to the globes. Note: The lucus definition of full illumination is not sufficient to see any light at all on the dash during the day. wait until after dark [preferably on a night with no moon] turn on the headlights via the normal switch in the centre of the lower dash pad, and then twiddle this knob. You may be lucky and wind up the brightness in the dash from nothing to 1.5 candle power. |
Author: | helen6521 [ Thu Jan 25, 2007 8:41 pm ] |
Post subject: | knob |
it a dash dimmer switch have one in mine |
