It is currently Tue Aug 12, 2025 5:51 pm
 Post subject: 2 Questions (with pics)
PostPosted: Thu Jan 25, 2007 10:46 am
Just a couple more questions while I remember...
There is a little knob on the drivers side, below and to the right of the steering wheel. It has a P and an arrow pointing right on it (see pic). Can anyone tell me what it's for? It doesn't appear to do anything when turned.
Also.. we have an annoying problem with our windscreen wipers. RARELY we can get them back to a nice finishing position, even though the finishing position has been adjusted by pulling them off, and putting them on in the right position. We were told the brass washer inside the mechanism is worn. Does anyone know where to get new ones, what they're called or what they look like? I'd love to have this fixed by the time the rains come!
Excuse the state of the mini, it needs some interior lovin'. ;) Thanks lots!
Manda & Marty
PostPosted: Thu Jan 25, 2007 10:49 am
the Knob looks like it could be a bonnet release, but i'm not certain. What comes out the back of it, and can you pull it out, like a choke.
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Thu Jan 25, 2007 10:53 am
The choke is on the left of the steering wheel, so it's not that. :D It doesn't pull, it turns, and there are wires coming out the back. I'm also certain it's not a bonnet release, as that's all done from the front. (ie: you don't need to get into the car to get into the bonnet, guess that's why they put the battery inside the car! :lol: )
Other ideas? :P
PostPosted: Thu Jan 25, 2007 10:54 am
The P knob is your dash panel brightness switch.
PostPosted: Thu Jan 25, 2007 10:55 am
These are stabs in the dark but it could be a dimmer for a light, or possibly a varible speed control for wippers.
Ryan Filippi
Minis In The Gong
[email protected]
PostPosted: Thu Jan 25, 2007 11:48 am
There are dash panel lights? :P Perhaps there is a globe out or something. We havn't driven at night yet! :oops: But when we've used the headlights, there isn't any dash panel light at all.
I didn't question it too much, it's a 76, perhaps they hadn't thought of that by then, since there aren't any reverse lights either! :wink:
Taking that apart will be fun, too! :)
PostPosted: Thu Jan 25, 2007 11:58 am
yupppo Scots on the money, It dims or brightens (or turns off) your instrument cluster lights
PostPosted: Thu Jan 25, 2007 12:16 pm
and thanks to mr lucas they dont always work :lol:
PostPosted: Thu Jan 25, 2007 12:23 pm
resident alien
resident alien
Found the horn yet?
PostPosted: Thu Jan 25, 2007 2:18 pm
Marvin wrote:
Found the horn yet?
Horn and I are well acquainted, thank you. ;) Although, it's hard to "blast" someone when it sounds just oh-so-cute! :roll:
 Post subject: mm1275
PostPosted: Thu Jan 25, 2007 4:15 pm
As for parking the wipers, the arms have prob been removed at some time and fitted in an incorrect position, So simply remove both arms, Find the reverse point (TDC) on the wiper pivot and refit the arms. SIMPLE.
*Reasonable pricing
*I come to you..
Jay: 0431404607
PostPosted: Thu Jan 25, 2007 5:58 pm
it is a potentiometer - lmao
Yes it is a dimmer for your lights - also turns them off when you turn them all the way CCW(or was it CW????)
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Thu Jan 25, 2007 6:00 pm
This is not turning on the dash lights [that is done at the headlights switch], but adjusting the brightness of them by rotating this knob in the direction of the arrow and back. At one end is full power to the globes at the other end of the sweep is no power to the globes.
Note: The lucus definition of full illumination is not sufficient to see any light at all on the dash during the day. wait until after dark [preferably on a night with no moon] turn on the headlights via the normal switch in the centre of the lower dash pad, and then twiddle this knob. You may be lucky and wind up the brightness in the dash from nothing to 1.5 candle power.
 Post subject: knob
PostPosted: Thu Jan 25, 2007 8:41 pm
it a dash dimmer switch have one in mine
Users browsing this forum: Timbo and 281 guests
