It is currently Sat Jul 19, 2025 5:36 am
PostPosted: Tue Jan 25, 2005 9:43 pm
Took it for a test run today with brakes done and new suspension in they were all fine. New problem to solve is violent vibration in area between gear stick and gear box when I let the clutch out in any gear - the whole car judders and it seems loose in that area. is this the clutch or gearbox problems - what should I check ? - please help !
1977 Clubman
PostPosted: Wed Jan 26, 2005 6:40 am
I'd say either your engine mounts are gone, or you have a crap clutch. See your other post. :wink:
PostPosted: Wed Jan 26, 2005 7:55 am
Hi,
Had a similar problem,spent a fortune replacing everything in the front end. Ended up being only one bolt connected to the remote housing instead of two. So everytime you,d take off or put a bit of accelleration on there would be knocking/shudder/vibration of the remote housing hitting the body.Worth a quick look.
