Need help - Floats on Fluid https://www.ausmini.com/forums/viewtopic.php?f=2&t=27231 |
Page 1 of 2 |
Author: | Mike_Byron [ Fri Jan 26, 2007 5:19 pm ] |
Post subject: | Need help - Floats on Fluid |
I am after a good high resolution photograph of the sticker "floats on fluid" that was applied to Morris 1100's and some minis. I am going to get the sticker reproduced and I will get a few extra done at the same trime for other who are interested. Can someone please supply the photo and if possible the dimensions of said same. Thanks in Advance. Mike |
Author: | demonic1100 [ Fri Jan 26, 2007 5:59 pm ] |
also if anyone has one of those better built better backed stickers leyland used to use i'd like to get a couple... come to think of it mitsubishi ripped leyland off with that... difference is leyland built decent cars mitsubishi..errrrr ummmmm well............... |
Author: | matt van'74 [ Fri Jan 26, 2007 6:31 pm ] |
demonic1100 wrote: difference is leyland built decent cars .....
Yeah, like the P76 ![]() I would check photos of Morris 1100, 1300 and 1500's. I will have a look for you and see what i can find ![]() |
Author: | Whitta [ Fri Jan 26, 2007 6:43 pm ] |
![]() ![]() If you need help reproducing it, PM me. |
Author: | matt van'74 [ Fri Jan 26, 2007 6:47 pm ] |
Just found the same one as Whitta and another one on the same site. ![]() ![]() Hope that helps |
Author: | demonic1100 [ Fri Jan 26, 2007 6:47 pm ] |
that one you could get away with doing in somthing like paint shop pro and for the better built better backed sticker i saw one in a magazine that i have know idea where it is... but i think it had somthing around the edge as well.. |
Author: | drmini in aust [ Fri Jan 26, 2007 6:55 pm ] |
Wasn't there a link to these a while back- someone on Morris 1100 forum was selling them? ![]() |
Author: | 9YaTaH [ Fri Jan 26, 2007 6:59 pm ] |
Post subject: | 1100 |
www.elevenhundred.com |
Author: | Mike_Byron [ Fri Jan 26, 2007 7:01 pm ] |
Somewhere here i lost a response of mine Basically Thanks fellas I would still love a good quality high resolution photo with the dimensions included. I will happily have a few extra made for those interested. Not a profit centre here, just cover costs. |
Author: | Morris 1100 [ Fri Jan 26, 2007 7:33 pm ] |
All the re-made ones I have seen have been too small. The ones on http://www.elevenhundred.com/stickers.php look about right. He sells them for $10. |
Author: | TimB [ Sat Jan 27, 2007 7:28 pm ] |
If someone has a picture of the whole window or car with the sticker on I can work out the exact size and I'd be happy to create the arwork in Adobe Illustrator for a professional looking job. ![]() Tim |
Author: | 9YaTaH [ Sat Jan 27, 2007 7:38 pm ] |
Post subject: | Sticker |
If it helps...I estimate/reckon about 6 inches from top to bottom...whaddayareckon Mike?? |
Author: | chopchop [ Sat Jan 27, 2007 8:50 pm ] |
i've already done the artwork in illustrator if i can find it, as morris 1100 said mine were too small, need to be a bit bigger. |
Author: | Mike_Byron [ Sat Jan 27, 2007 8:55 pm ] |
Sounds good to me The actual clinically accurate dimensions are not important. Folks in Gulgong are more likely to come up and talk about the 1100 thay used to drive to the bowls match than get out a micrometre and measure the dimensions. I do also remember the corruptions of that sticker - floats on saki, floats on pure enthanol, floats on etc ....... I will check out the other site - the sticker is inside mounted facing out. |
