Compression Test results https://www.ausmini.com/forums/viewtopic.php?f=2&t=27273 |
Author: | birty [ Sat Jan 27, 2007 2:31 pm ] |
Post subject: | Compression Test results |
Hi all, I have just done a warm engine compression test on my 1275. This engine (mini) was taken off the road back in 1996 and the last time it was turned over was back in 2000. I turned (ie idling) her over about 2 weeks ago and this time today I had the equipment to test the engine. I did not squirt any oil down the spark plug holes beforehand. From right to left (facing the car) - sorry don't cyclinder number specifics: 1: 150 2: 140 3: 150 4: 125 How is this for an engine. I think it is ok but the 125 was a bit lower than the others though. |
Author: | drmini in aust [ Sat Jan 27, 2007 2:35 pm ] |
10psi variation is considered normal, but 25 is a slight worry. If it's been parked years it could just be a bit of corrosion on a valve seat. I'd run it a bit, adjust the valves, then redo the test. ![]() |
Author: | birty [ Sat Jan 27, 2007 2:37 pm ] |
Thankd Drmini, What would be a good result for a compression test. Is 150 ok or should it be higher? |
Author: | drmini in aust [ Sat Jan 27, 2007 3:40 pm ] |
The compression pressure you get depends on lots of things, chiefly the C/R, and the camshaft specs. So hard to say without knowing this. More important is lack of variation between cylinders, if you are checking engine condition. BTW I hope you are holding the throttle pedal down, and spinning it with all plugs out. ![]() |
Author: | birty [ Mon Feb 05, 2007 2:05 pm ] |
Well, good news. I let the engine idle for 2x20 minute sessions and did another compression test today. The cylinder that was only getting 125 was now hitting 145. As DrMini stipulated - must have been a bit of corrosion on the valve. At least this is one positive for this engine but then again I never pushed Frodo hard for the 5 years I was running him back in the 1990s and I was always diligent with general maintenance. |
Author: | ziff [ Mon Feb 05, 2007 4:11 pm ] |
Sounds a little better than my 998 at the moment. When I tested it the other day I ended up with the following: 1 = 55 2 = 125 3 = 125 4 = 125 I'm also getting pressure forcing oil out around the dip stick. Oh well, might have to tend to that soon ![]() Ziff |
Author: | slinkey inc [ Mon Feb 05, 2007 5:11 pm ] |
that 55 is a worry.... |
