It is currently Sat Jul 12, 2025 8:57 am
PostPosted: Sun Jan 28, 2007 8:11 pm
As it says... How much is a 1100 crank worth? Maximum price for a standard one.
Mike
If it cant be fixed with a hammer it cant be FIXED!!
PostPosted: Sun Jan 28, 2007 8:19 pm
I paid $75 for a big journal 1275 crank. It was standard journals but had slight scoring. It polished up without grinding undersize.
I would assume that something similar applies to a good second hand 1100 crank.
New is an entirely different ball game and probably depends on how badly others want it.
PostPosted: Sun Jan 28, 2007 8:35 pm
When I say 1100 I mean for a small bore engine.. As in 1100 cc not a 1100 1275 engine
mike
PostPosted: Sun Jan 28, 2007 8:49 pm
I sold mine (1098) for $50.
You want one that will clean up with regrind at -.010" or -.020".
PostPosted: Sun Jan 28, 2007 8:57 pm
What about this one Dr Mini?
http://cgi.ebay.com.au/Mini-1100-Cranks ... dZViewItem
Mike
PostPosted: Sun Jan 28, 2007 9:22 pm
ask him what size the mains and big ends are now. :wink:
If you buy, make sale subject to a crack test. These are old cranks....
BTW the dude who was asked Q and was talking about the 997 crank longer? stroke is full of it, they are 0.096" less stroke than an 1100 is. :lol:
PostPosted: Sun Jan 28, 2007 9:53 pm
Will ask him now ... So if I win the bid and then hes sends me te crank who do I send the crank too to get it crack tested?
Mike
PostPosted: Sun Jan 28, 2007 9:55 pm
Yeah - I realised it was for a small bore - just making a comment on relative values. Sorry if it didn't seem that way.
PostPosted: Sun Jan 28, 2007 10:02 pm
i sold one a while ago for $70 8)
@#$%Things are not what they used to be
Missing one inside of me
Deadly loss, this can't be real
Cannot stand this hell I feel
Emptiness is filling me
To the point of agony
Growing darkness taking dawn.
PostPosted: Sun Jan 28, 2007 10:11 pm
Look, there is an easy way to get an idea of if a crank is cracked - its not fool proof but.... its a good guide.
Simply suspend it with a bit of string etc. Something so its not "earthed" so to speak.
Then give one end a tap with a small hammer. If you get a long "ring" sound then its okay. If you get a dull tink sound then its cracked.
Try it or ask others !
PostPosted: Mon Jan 29, 2007 6:06 am
You can stand it on its nose and tink the webs with a spanner. Good indication.
Not foolproof though, Chong got caught with one.... was cracked at centre main and still rang nice. :lol:
Magnaflux or black light fluorescent dye test is best, but `dyecheck' is cheaper, and works. :wink:
Best get your crank grinder to check it before grinding. This applies to any crank, but 998 ones are less likely to be bad.
PostPosted: Mon Jan 29, 2007 9:41 am
Ding test is bogus! beware!
PostPosted: Mon Jan 29, 2007 10:15 am
Actually the ding test DOES serve a good purpose. If it's dull, don't bother proceeding, and you've saved yourself some dosh. If it rings true, get it tested properly.
PostPosted: Mon Jan 29, 2007 10:21 am
You got a point there. But my point is that mine dinged nicely all the way up and down the whole crank but there was still a HUGE crack on the center main (where they are prone to cracking).
I think the ding test will only work if the crak is on the counterweight/blade of the crank? who knows...
PostPosted: Mon Jan 29, 2007 1:00 pm
What's it actually called?
I've heard of it referred to as a " tong test"
Whoever is talking to GR or Spiro next - ask them willya!! :D
KB
