is it legal https://www.ausmini.com/forums/viewtopic.php?f=2&t=27330 |
Page 1 of 2 |
Author: | MRClubby1098 [ Sun Jan 28, 2007 2:09 pm ] |
Post subject: | is it legal |
Hey everyone i was thinking of debumpering my clubman mini, but im not sure because i don't no if it will be legal or not.... need some help plz Todd ![]() |
Author: | gafmo [ Sun Jan 28, 2007 2:11 pm ] |
Godd I hope so...I have nearth front nor back |
Author: | buztoy [ Sun Jan 28, 2007 2:31 pm ] |
back de-bumpering is called smooth ass mini ![]() |
Author: | MRClubby1098 [ Sun Jan 28, 2007 2:39 pm ] |
lol oh ok then... well i might take them off and if i get a defect, ill just put them back on, easy as that ![]() |
Author: | buztoy [ Sun Jan 28, 2007 2:41 pm ] |
you gotta deseam it as well, |
Author: | slinkey inc [ Sun Jan 28, 2007 4:26 pm ] |
My car came de-bumpered. But I wanted bumpers so I bolted on 'L' brackets to the body to mount bumpers. So it is possible to bumper a bumperless mini. But you can't compete in any motorsport events at the 'Hay Mini Nationals' as it's a rule that all cars must ahve bumpers to compete. But if ya don't care and wanna look awesome, then go for it. As for being legal...I have no idea! |
Author: | demonic1100 [ Sun Jan 28, 2007 5:24 pm ] |
it's legal as long as there are not sharp edges under neath... |
Author: | MRClubby1098 [ Sun Jan 28, 2007 7:50 pm ] |
woohooo well ill be doing it...... im not goin to deseam it im just going to put the crome cover strip over it, it should look ok ![]() ![]() |
Author: | Mike [ Sun Jan 28, 2007 8:39 pm ] |
The front bumpers are mounted on a sharp horizontal seam lip. If you just remove the bumpers w/o removing the lip you might as well mount a sharp blade across the front of your car - the impact to a pedestrian's legs at anything over 5 mph should be just the same. I know it looks kinda cool with just the lip there (and I dont wanna sound like those guys on this forum who warn of doom and apocalipse everytime one asks about using hotter spark plugs or a diferent air filter), but please consider the consequences if you do hit a pedestrian with that lip. And if you won't, atleast consider the consequences to yourself if you hit a pedestrian in an illegaly modified car with a blade shaped frontal area. |
Author: | sports850 [ Sun Jan 28, 2007 8:43 pm ] |
Mike wrote: The front bumpers are mounted on a sharp horizontal seam lip. If you just remove the bumpers w/o removing the lip you might as well mount a sharp blade across the front of your car - the impact to a pedestrian's legs at anything over 5 mph should be just the same.
Not on a clubman Mike , their front bumper fixes by 4 bolts on a pretty much flat panel , clubmans with a spoiler look good bumperless .The rear is similar to a roundies front though and has the horizontal seam that needs to be remove , just putting a chrome strip over it will probably get defected at some stage but being the rear you may be lucky with it . |
Author: | MRClubby1098 [ Sun Jan 28, 2007 10:05 pm ] |
when i do it ill have a look at it and if there is any danger to a padestian i will deseam it... |
Author: | gafmo [ Sun Jan 28, 2007 10:36 pm ] |
Don't forget people shins walking around your Car..and yourself |
Author: | Mike [ Mon Jan 29, 2007 5:15 am ] |
sports850 wrote: Mike wrote: The front bumpers are mounted on a sharp horizontal seam lip. If you just remove the bumpers w/o removing the lip you might as well mount a sharp blade across the front of your car - the impact to a pedestrian's legs at anything over 5 mph should be just the same. Not on a clubman Mike , their front bumper fixes by 4 bolts on a pretty much flat panel , clubmans with a spoiler look good bumperless .The rear is similar to a roundies front though and has the horizontal seam that needs to be remove , just putting a chrome strip over it will probably get defected at some stage but being the rear you may be lucky with it . Sorry, I just automaticaly assumed a roundnose. My mistake. |
Author: | birty [ Mon Jan 29, 2007 8:02 am ] |
This is the front of a Clubman without the bumper. I don't know whether the two raised sections would need to be removed though. ![]() |
Author: | sports850 [ Mon Jan 29, 2007 8:10 am ] |
If you wanted to get really technical , having the bumper removed might leave the number plate too far forward and that could be a sharp edge to cut your leg on walking past , I never had any problem with mine debumpered at the front , I did put chromed cup head bols in the bumper mount holes to make it look finished though . I'll try and find a pic to show it . |
