How much to pay for a 1100 crank? 1100cc crank https://www.ausmini.com/forums/viewtopic.php?f=2&t=27350 |
Author: | Mini Mike [ Sun Jan 28, 2007 8:11 pm ] |
Post subject: | How much to pay for a 1100 crank? 1100cc crank |
As it says... How much is a 1100 crank worth? Maximum price for a standard one. Mike |
Author: | Mike_Byron [ Sun Jan 28, 2007 8:19 pm ] |
I paid $75 for a big journal 1275 crank. It was standard journals but had slight scoring. It polished up without grinding undersize. I would assume that something similar applies to a good second hand 1100 crank. New is an entirely different ball game and probably depends on how badly others want it. |
Author: | Mini Mike [ Sun Jan 28, 2007 8:35 pm ] |
When I say 1100 I mean for a small bore engine.. As in 1100 cc not a 1100 1275 engine mike |
Author: | drmini in aust [ Sun Jan 28, 2007 8:49 pm ] |
I sold mine (1098) for $50. You want one that will clean up with regrind at -.010" or -.020". |
Author: | Mini Mike [ Sun Jan 28, 2007 8:57 pm ] |
What about this one Dr Mini? http://cgi.ebay.com.au/Mini-1100-Cranks ... dZViewItem Mike |
Author: | drmini in aust [ Sun Jan 28, 2007 9:22 pm ] |
ask him what size the mains and big ends are now. ![]() If you buy, make sale subject to a crack test. These are old cranks.... BTW the dude who was asked Q and was talking about the 997 crank longer? stroke is full of it, they are 0.096" less stroke than an 1100 is. ![]() |
Author: | Mini Mike [ Sun Jan 28, 2007 9:53 pm ] |
Will ask him now ... So if I win the bid and then hes sends me te crank who do I send the crank too to get it crack tested? Mike |
Author: | Mike_Byron [ Sun Jan 28, 2007 9:55 pm ] |
Yeah - I realised it was for a small bore - just making a comment on relative values. Sorry if it didn't seem that way. |
Author: | MRClubby1098 [ Sun Jan 28, 2007 10:02 pm ] |
i sold one a while ago for $70 ![]() |
Author: | Mike_Byron [ Sun Jan 28, 2007 10:11 pm ] |
Look, there is an easy way to get an idea of if a crank is cracked - its not fool proof but.... its a good guide. Simply suspend it with a bit of string etc. Something so its not "earthed" so to speak. Then give one end a tap with a small hammer. If you get a long "ring" sound then its okay. If you get a dull tink sound then its cracked. Try it or ask others ! |
Author: | drmini in aust [ Mon Jan 29, 2007 6:06 am ] |
You can stand it on its nose and tink the webs with a spanner. Good indication. Not foolproof though, Chong got caught with one.... was cracked at centre main and still rang nice. ![]() Magnaflux or black light fluorescent dye test is best, but `dyecheck' is cheaper, and works. ![]() Best get your crank grinder to check it before grinding. This applies to any crank, but 998 ones are less likely to be bad. |
Author: | Lillee [ Mon Jan 29, 2007 9:41 am ] |
Ding test is bogus! beware! |
Author: | smac [ Mon Jan 29, 2007 10:15 am ] |
Actually the ding test DOES serve a good purpose. If it's dull, don't bother proceeding, and you've saved yourself some dosh. If it rings true, get it tested properly. |
Author: | Lillee [ Mon Jan 29, 2007 10:21 am ] |
You got a point there. But my point is that mine dinged nicely all the way up and down the whole crank but there was still a HUGE crack on the center main (where they are prone to cracking). I think the ding test will only work if the crak is on the counterweight/blade of the crank? who knows... |
Author: | 1310/71 [ Mon Jan 29, 2007 1:00 pm ] |
What's it actually called? I've heard of it referred to as a " tong test" Whoever is talking to GR or Spiro next - ask them willya!! ![]() KB |
