Simple changes that really work https://www.ausmini.com/forums/viewtopic.php?f=2&t=27367 |
Author: | matt850 [ Mon Jan 29, 2007 9:22 am ] |
Post subject: | Simple changes that really work |
Last week I added the sound deading / insulation to the fire wall. Cant believe I'm in the same car. Also changed from side entry dizzie cap to front entry to accomodate 8mm leads and not only does it go better but it now likes to go "singing in the rain". Best small outlay of dollars so far I reckon. |
Author: | Lillee [ Mon Jan 29, 2007 9:31 am ] |
Oh yeah, I have found the smallest things will make huge differences! take wheel alignment, you'd be amazed what 1.5mm will do to the handling of the car! |
Author: | MRClubby1098 [ Mon Jan 29, 2007 11:35 am ] |
i put 10mm split fire leads on and it made a difference.... also put a breather filter on the hose that goes into the side of the carby, instead of letting the carby suck the hot crap air from the tapper cover.... you'll be suprize on how well this works. ![]() |
Author: | >Rude< [ Mon Jan 29, 2007 1:19 pm ] |
what sound deadening/insulation did you use?? cheers >Rude< |
