Rust Treatment and Prevention
https://www.ausmini.com/forums/viewtopic.php?f=2&t=2739
Page 1 of 2
Author:  Chris [ Tue Nov 09, 2004 7:27 am ]
Post subject:  Rust Treatment and Prevention
Has anyone used POR15 rust prevention treatment? Info at this link.......
http://www.ppc.au.com/webcontent16.htm
Author:  gafmo [ Tue Nov 09, 2004 7:31 am ]
I'm about to ....Marine Clean today and then Metal Ready then the POR15 Gloss black first coat hopfully. You know me I'll put some pic's in Maria Turns (photo Gall). :lol:
I have taken the hole Engine bay and gaurds back to bare metal. If anyone wants to get dirty this is the job :x
Author:  J_A_M [ Tue Nov 09, 2004 7:38 am ]
yea I wanted to use that stuff, but the price put me off.
I will be using Marine Clean and Metal Ready in my fuel tank, which has rusted INSIDE! :shock:
Author:  Chris [ Tue Nov 09, 2004 7:39 am ]
Can I apply it over primer or has it got to be bare metal? What happens after the application? Just a normal sprayed primer coat?
Author:  gafmo [ Tue Nov 09, 2004 7:45 am ]
As per thier fact sheet.
CAN I APPLY POR15 OVER OTHER PAINTS.
Yes but you will lose the important benifits. You must rember that ordinary paints are weaker by exposure to moisture. POR15 can not stop rust if it isn't direct contact with the base metal
Author:  sweep77 [ Tue Nov 09, 2004 10:43 am ]
will you put a top coat on? it says it needs it if exposed to sunlight. not that a subframe is really exposed to (direct)sunlight. what topcoat would be used?
Author:  sweep77 [ Tue Nov 09, 2004 10:53 am ]
also how much of the por15, marine cleaner, metal cleaner and solvent is needed to do the two subframes?
Author:  gafmo [ Tue Nov 09, 2004 11:37 am ]
At this stage I dont intend to put a top coat on as its going in the front subframe and Engine Bay...I have no idea how much coverage at this stage as its my first with it also :lol:
Author:  Wolfman [ Tue Nov 09, 2004 12:02 pm ]
Has anyone used or considered electronic rust prevention after a full back to metal restore?
I assume they do work, the old mans AUII came with one.
Author:  mutant mini [ Tue Nov 09, 2004 2:03 pm ]
Not used one but A Grade Panels here in Melbourne are an agent for one of those companies. I do know someone who has installed one on their Cooper S. Didn't do a bare metal re-spray though.
You can look at details I think at http://www.agradepanels.com.au
Author:  mickmini [ Tue Nov 09, 2004 2:34 pm ]
what about cathodic protection? hmmm
galvanising? bolting a hunk of zinc in a atrategic spot as a sacrificial anode?
just ideas that work in other applications (including Mokes:!:)
Author:  mrcooms [ Tue Nov 09, 2004 3:11 pm ]
OMG studying chem actually was useful i understant what u are going on about. Maybe it wasnt a waste of time afterall :P :P
Author:  68matic [ Tue Nov 09, 2004 3:16 pm ]
anton talk to steve from steveandmikey
he'll tell you what dave does
and says
and you wont be so surprised about the 'magical' effects of POR15
and daves way which is excatly same is cheaper i think
Author:  sweep77 [ Tue Nov 09, 2004 4:04 pm ]
my old chem teacher said all you need to do is make up a small box and attach it to the chassis, fill it with cotton wool soaked in salt water and place some magnesium or i guess zinc(easier to get i think) in there and seal it up. Just replace it about every 10 yrs. Magnesium will corrode instead of your mini :lol:
Author:  Namibian CAMEL [ Tue Nov 09, 2004 6:40 pm ]
mrcooms says
Here here :wink:
