Power loss and backfiring
https://www.ausmini.com/forums/viewtopic.php?f=2&t=27496
Page 1 of 2
Author:  TasTyger [ Wed Jan 31, 2007 1:21 pm ]
Post subject:  Power loss and backfiring
After getting the 1275 installed in my moke and tuned she was running really well until the last week or so. Now I have days when I put my foot down and she is responding but other times feels like she is having a struggle to get power up. Alsp pop,popin' back through the exhaust. Only things I have done since tuneup was put in new plugs and replace the ramflo foam for a unifilter one.
Currently running on Premium fuel as near all BP outlets in Hobart are out of Ultimate ?? 1275 is near stock with 1 1/2" carby, ramflo airfilter (300 series), extractors and 1 3/4" exhaust system. Fuel filter is brand new.
Dizzy is 45DM4 with Lucas AB14 electronic ignition module if that has any bearing on things.
Quite puzzling??
TasTyger :?
Author:  sports850 [ Wed Jan 31, 2007 1:23 pm ]
Just check the dizzy clamp to start with and see if it's loose enough to move , the motor might be setting it's own variable timing :oops: . At least it's a quick and easy one to rule out .
Author:  Lillee [ Wed Jan 31, 2007 3:06 pm ]
Ausmini is going strange, I can write and reply to this post but I can't write what I want to write which is the reply to this post! :?
Author:  sports850 [ Wed Jan 31, 2007 3:08 pm ]
Depends on what words you are using , it wouldn't let me use a well known manifold maker from the 70's last week , try using spaces in between the letters of any odd word and see if it works .
Author:  Lillee [ Wed Jan 31, 2007 3:08 pm ]
it is giving me a
Forbidden
You don't have permission to access /forums/posting.php on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Apache/1.3.37 Server at www.ausmini.com Port 80
when I try to write what I want to write, but when I type anything else it is allowing me to post
Author:  Lillee [ Wed Jan 31, 2007 3:09 pm ]
Bingo!
You'd be surprised how much of a difference the uni filter is compared to the ly nx element. The uni filter breathes almost like it has no filter (almost). I bet it has thrown out your jetting.
Just to give you an idea, when I tried the ly nx filter this week on my 1330 with dell orto, I had to screw in the idle screws (leaner) a whole 3 turns in order to make it run normal. When i replaced it with the unifilter, I had to screw it out 3 turns (richer) as it was breathing so much better.
Check your jetting, adjust it slightly to make it run alittle more rich and see how you go.
Did you oil up the element too much? it should arelady come oiled. Try to squeeze out the excess, it should only need light oiling...
Author:  Lillee [ Wed Jan 31, 2007 3:10 pm ]
WHAT THE??? so we are being censored for manufacturers names on Ausmini??
the words "L y n x" won't work if you try to post it??
Author:  sports850 [ Wed Jan 31, 2007 3:11 pm ]
Yeah , that's the message you get when you use a word that the forum thinks is an instruction for it to do something other than post a message , I tried to post a message saying a l y n x manifold and it threw a wobbly . Try and be creative with the spelling of anything like that and you should be right .
EDIT after seeing chongs recent post - It seems the manufacturers name is also an instruction to the forum that it should do something that we aren't authorised to do , hence it won't allow us to post anything with it ....
Author:  Lillee [ Wed Jan 31, 2007 3:12 pm ]
Lynx
SPOOOOKY!!! *crawls in corner in fetal position*
Author:  adeee [ Wed Jan 31, 2007 3:16 pm ]
i think its only if you post ly nx in a sentance that it cracks it
EDIT/ yep, just happened to me
EDIT AGAIN/ just posted a single word post and that word worked, so i must be right.
Author:  willy [ Wed Jan 31, 2007 3:20 pm ]
Lynx
Author:  adeee [ Wed Jan 31, 2007 3:23 pm ]
i can do that too will, now prove us wrong and post it in a sentance...
Author:  Lillee [ Wed Jan 31, 2007 5:22 pm ]
haha, ok back to the topic! :wink:
Author:  TasTyger [ Thu Feb 01, 2007 6:58 am ]
Cheers for responses. will look into the filter change. Would the state of the plugs also give an indication whether she is running lean or rich. The electrodes on the just replaced plugs are a ghosty ash white?? :?
TasTyger :)
