Wheelbase?? https://www.ausmini.com/forums/viewtopic.php?f=2&t=27570 |
Author: | WasabiPimpNinja [ Fri Feb 02, 2007 8:36 am ] |
Post subject: | Wheelbase?? |
Just a quick question, is the wheelbase of a Clubby van the same as a Roundy van? So far from searching the site I've come up with: Std Mini: 2036mm Clubby Van: 2134mm Are these correct? Also is there a difference between Clubby and Roundy sedans?? Cheers peeps. Peace. |
Author: | sports850 [ Fri Feb 02, 2007 8:50 am ] |
No wheelbase diferences between clubbies or roundies , the only differences really were cosmetic , I'm not even sure if there was much overall length difference inclubbies to roundies , just the bumper is a little further out in a clubbie . |
Author: | >Rude< [ Fri Feb 02, 2007 12:27 pm ] |
isnt the engine bay bigger in a clubby??? |
Author: | awdmoke [ Fri Feb 02, 2007 12:38 pm ] |
Yes, but that is just due to it's square shape |
Author: | sports850 [ Fri Feb 02, 2007 12:48 pm ] |
If you were to continue a roundie bonnet horizontally from the top to where it meets the vertical line from the front bumper you would have roughly the clubman shape/dimensions , they aren't much bigger than a roundie really , just seems that way . |
Author: | JC [ Fri Feb 02, 2007 1:18 pm ] |
I disagree.... Where the subframe meets the front of a morris the engine bay essentially rolls up and BACK from that point. Whereas the clubman engine bay protrudes forward of the subframe mounting point a good few inches and then goes STRAIGHT up. |
Author: | AEG163job [ Fri Feb 02, 2007 3:44 pm ] |
I've nuthin' against Clubbies, but the extra room under the bonnet is a waste of space......... ![]() |
Author: | Morris 1100 [ Fri Feb 02, 2007 5:15 pm ] |
Clubies are 5 inches longer than roundies. ![]() Mini Deluxe = 10' ¼" or 3.084 metres. Mini Clubman = 10' 5¼" or 3.13 metres. Mini 1100 Van (Clubman van) = 3.42 metres. |
Author: | Mick [ Fri Feb 02, 2007 5:18 pm ] |
Yeah there is a band of metal welded into the floor pan somewhere behind the seats I remember. |
Author: | TheMiniMan [ Fri Feb 02, 2007 7:45 pm ] |
wheel base difference from a sedan to a van is approx 4 inches , whether it be clubby or roundy means nothing with regards to the wheel base, The original floor pan stops where the sedan one does & they then added the 4inch section to the back of that for a van. "Overall" length is a different matter & therfor the longest overall length mini is the clubby van. easy-peasy. |
