It is currently Mon Jul 28, 2025 12:14 pm
 Post subject: sliding windows
PostPosted: Sat Feb 03, 2007 2:05 pm
can anyone tell me the step by step of getting sliding windows in
PostPosted: Sat Feb 03, 2007 3:20 pm
theres plenty of manuals that give you step by steps
PostPosted: Sat Feb 03, 2007 7:43 pm
i did this just recently...
but to clarify first...
do you have sliding window doors and want to replace the glass/channels or do you want to convert windup windows to sliders?
for the later you'll need to fit sliding window doors....
for the former,you need to get the three screw in the channel out (i had to drill mine) :x
then you slide both windows open a bit (to the middle, so there's a gap on either side) then you pull the glass out from the bottom. by grabbing chrome rail and the channel and pulling inwards and then down....having a friend to help catch the glass is a good idea...
and then the magic words..
"installation is the reverse of removal" :P
other than that...it's in the early workshop manuals...in the later ones, it's in the van section.. ;)
PostPosted: Sun Feb 04, 2007 11:25 am
doesnt matter i have given up i will get someone that has done them b4 to put them in the trouble i am have is when i put the windows in the new channel the windows allways end up on the same run
 Post subject: mm1275
PostPosted: Sun Feb 04, 2007 12:50 pm
Can you convert wind up's to sliding? has any1 done it?
*Reasonable pricing
*I come to you..
Jay: 0431404607
PostPosted: Sun Feb 04, 2007 2:40 pm
On roundnoses (not clubby doored Ks) you can swap doors. My car has windups, but is suppose to have sliders.
