12 inch wheels
https://www.ausmini.com/forums/viewtopic.php?f=2&t=27613
Page 1 of 2
Author:  indy [ Sat Feb 03, 2007 10:03 pm ]
Post subject:  12 inch wheels
This might be a silly question but can I change from 10 inch wheels to 12 inch wheels without any modification to my clubman? :?
Author:  Mini Mike [ Sat Feb 03, 2007 10:04 pm ]
Sure can
Author:  indy [ Sat Feb 03, 2007 10:07 pm ]
Great :D . Does it affect the handling, acceleration, braking etc of the car?
Author:  1018cc [ Sat Feb 03, 2007 10:11 pm ]
They should be fine, just don't go for extremely wide wheels - stick to 12x5's for example. I have heard (never tried - I like the look of 10's way too much) that the ride isn't as nice because there isn't as much tyre wall to soak up the bump, so 10's are better in that respect.
Lower profile tyres are better for handling (the 12's will have lower profile tyres on them) because there is less tyre wall to distort when having cornering loads put on them.
Author:  indy [ Sat Feb 03, 2007 10:14 pm ]
Excellent. Thanks for the advice :D
Author:  mad-mk1 [ Sun Feb 04, 2007 1:15 am ]
yep not too wide like what has been mentined
run yoko a539s rice tyre
i think they dtill amke em or are discontinuing them or sumin!
i ran 10x7 on my clubby with only step drums, most fun ive had!
Author:  Spaceboy [ Sun Feb 04, 2007 1:26 am ]
you shouldnt notice much difference between 10's and 12's, and you wont require any modifications, just bolt on and go...
Author:  coops [ Sun Feb 04, 2007 2:14 am ]
I would suggest a front end wheel alignment though as they are that little bit bigger (1"?circumference) so that does change it.
Mine understeer'd like a bitch but all is good now since wheel alignment.
Author:  smac [ Sun Feb 04, 2007 4:29 am ]
Actually many 12's will foul the front guards if caster is set correctly, so the guards may need to be cut.
Author:  Smokie [ Sun Feb 04, 2007 7:41 am ]
I run 12" wheels on my LS and the only modification I had to do was to hammer the lower corner of the guard out of the way after I put on new adjustable tie bars. Before that it was just bolt on wheels without any mods..
Author:  MRClubby1098 [ Sun Feb 04, 2007 8:10 am ]
10's do look nice but im going with the 12'' as well, they should really make my clubby stand out 8)
Author:  LS1380 [ Sun Feb 04, 2007 8:42 am ]
They all look good 8) First 10's
Then 12's
And 13's :)
Author:  MRClubby1098 [ Sun Feb 04, 2007 8:48 am ]
hey LS1380, thoes 12'' on the clubby are they 5'' wide or 6'' they look sexy 8) ill be getting a set for my clubby 8)
Author:  LS1380 [ Sun Feb 04, 2007 8:53 am ]
Yes-Performance wheels 12x5
Author:  MRClubby1098 [ Sun Feb 04, 2007 9:13 am ]
mmmmm nice 8) i was thinking 12x6 but ill just go 12x5
