It is currently Tue Jul 22, 2025 5:07 am
 Post subject: Compression Test results
PostPosted: Sat Jan 27, 2007 2:31 pm
Hi all,
I have just done a warm engine compression test on my 1275. This engine (mini) was taken off the road back in 1996 and the last time it was turned over was back in 2000. I turned (ie idling) her over about 2 weeks ago and this time today I had the equipment to test the engine.
I did not squirt any oil down the spark plug holes beforehand.
From right to left (facing the car) - sorry don't cyclinder number specifics:
1: 150
2: 140
3: 150
4: 125
How is this for an engine. I think it is ok but the 125 was a bit lower than the others though.
Rob.
PostPosted: Sat Jan 27, 2007 2:35 pm
10psi variation is considered normal, but 25 is a slight worry.
If it's been parked years it could just be a bit of corrosion on a valve seat.
I'd run it a bit, adjust the valves, then redo the test. :wink:
PostPosted: Sat Jan 27, 2007 2:37 pm
Thankd Drmini,
What would be a good result for a compression test. Is 150 ok or should it be higher?
Rob.
PostPosted: Sat Jan 27, 2007 3:40 pm
The compression pressure you get depends on lots of things, chiefly the C/R, and the camshaft specs.
So hard to say without knowing this.
More important is lack of variation between cylinders, if you are checking engine condition.
BTW I hope you are holding the throttle pedal down, and spinning it with all plugs out. :wink:
PostPosted: Mon Feb 05, 2007 2:05 pm
Well, good news.
I let the engine idle for 2x20 minute sessions and did another compression test today.
The cylinder that was only getting 125 was now hitting 145. As DrMini stipulated - must have been a bit of corrosion on the valve.
At least this is one positive for this engine but then again I never pushed Frodo hard for the 5 years I was running him back in the 1990s and I was always diligent with general maintenance.
Rob.
PostPosted: Mon Feb 05, 2007 4:11 pm
Sounds a little better than my 998 at the moment. When I tested it the other day I ended up with the following:
1 = 55
2 = 125
3 = 125
4 = 125
I'm also getting pressure forcing oil out around the dip stick. Oh well, might have to tend to that soon :cry:
Ziff
PostPosted: Mon Feb 05, 2007 5:11 pm
that 55 is a worry....
