the saga continues, my mini is behaving weirdly AGAIN https://www.ausmini.com/forums/viewtopic.php?f=2&t=27712 |
Page 1 of 2 |
Author: | Dylans Clubby [ Tue Feb 06, 2007 2:48 pm ] |
Post subject: | the saga continues, my mini is behaving weirdly AGAIN |
ok so i've been ahvig a pretty good run with armageddon lately, he's been behaing himself. up until recently. he has started to lose coolant at an alarming rate (eg about half a litre a day) and is overheating as a result. i had the plugs out today, they had a decent amount of carbon foulin on them but there were no signs of water in there, i woulnd the engine on a bit to see if there was any in there but no, none. yet to ahve a look at the water pump though, gotta get on that. so this morning i cleaned up the plugs, topped up oil and coolant (took about 500-1000ml of oil, and filled coolant with motor running), and the temp is not evne reaching the N on the gauge????? interesting ![]() PS no mayo in oil filler cap |
Author: | Betty [ Tue Feb 06, 2007 3:38 pm ] |
Maybe your Armageddon is just thristy ![]() My new green mini Turtle JAC is also a coolant muncher. 3L in two days ... ![]() i just buy him more coolant. our cars can be friends. christmas colours! ![]() |
Author: | poeee [ Tue Feb 06, 2007 3:39 pm ] |
Don't talk to me about overheating! ![]() |
Author: | Smokie [ Tue Feb 06, 2007 3:44 pm ] |
Quote: Don't talk to me about overheating!
You getting hot under the collar Scott because Adeee is making you clean your room/s????? ![]() ![]() |
Author: | Dylans Clubby [ Wed Feb 14, 2007 11:36 am ] |
UPDATE: since spending about a day under the N, i'm regularly having overheating problems. where could the coolant be going??? also i've just re-read my post above...i sounded really drunk! im just bad with typo's i think i've caught something off makka hahahahaha |
Author: | Hanra [ Wed Feb 14, 2007 11:40 am ] |
Maybe theres a hole in ur coolant system dear lizza dear lizza? Go to a radiator joint and get a pressure test done, will take 30 secs to identify if there is a leak, should cost you free dollars. |
Author: | 1360 LS [ Wed Feb 14, 2007 12:00 pm ] |
I used to have this same problem..... I ended up flushing it everything I could think off. The problem wasn't anything remotely major, it was a hairline crack in the bottom rad hose barely visible until I shown a bright light down it and block off the other end. best of luck fixing the problem |
Author: | Dylans Clubby [ Tue Feb 20, 2007 1:26 pm ] |
yeah gotta get a pressure test done, i think natrad are doing them free atm. im thinking it could be a cracked hose, the rad is less that a year old so i'm fairly sure its fine. noticed hissing noise coming from rad cap, so changed it (but not same pressure, i think this new old one has a greater pressure) so pressure test here we come! with a lot o luck its not the head or gasket i'v had enough of that. gotta get the block properly done |
Author: | cush [ Tue Feb 20, 2007 1:29 pm ] |
check cooling system (flush/look for air) check mixture (a lean engine is a hot engine) |
Author: | Dylans Clubby [ Tue Feb 20, 2007 2:04 pm ] |
hmmmm i am running lean... i also think my choke is stuck out a bit though. how to fix? |
Author: | cush [ Tue Feb 20, 2007 2:07 pm ] |
push it back in from under the engine bay... |
Author: | Dylans Clubby [ Tue Feb 20, 2007 2:30 pm ] |
cheers ![]() |
Author: | Stuwey [ Tue Feb 20, 2007 2:53 pm ] |
Did you replace the rad cap? Mine started to lose an amazing amount of coolant (water ![]() Turned out the rad cap had corroded and it wasn't holding the spring down enough, so no pressure. $12 and it was fixed ![]() |
Author: | Dylans Clubby [ Wed Feb 21, 2007 9:11 am ] |
hey zoidberg. i did hange the rad cap but it was with an old one which i think i took off my car a couple of years ago. if i buy a new one, what pressure do i need? (also the one with the long spring...) |
Author: | Stuwey [ Wed Feb 21, 2007 10:22 am ] |
13psi ![]() |
