Matt with yet another stupid question...
https://www.ausmini.com/forums/viewtopic.php?f=2&t=2778
Author:  minstar [ Thu Nov 11, 2004 8:25 am ]
Post subject:  Matt with yet another stupid question...
Dry Cones, do you just grab them by the trumpet and yank them out? I expect to get heaped on from this...
Matt
Author:  czerial [ Thu Nov 11, 2004 8:34 am ]
there are no stupid questions..just stupid people :lol: :lol:
(as if i can talk.)
Yep when taking them out they may need a little
but of help, but they should just comer out (unless
its the front, you then need the tool i think or if
they are all squashed you may not need it)
Then again, i am usually wrong so maybe you
shouldn't listen :lol:
Author:  J_A_M [ Thu Nov 11, 2004 8:41 am ]
The trumpet is connected to the cone bone...the cone is connected to the subframe bone....aaaggghhhh...see what happens when you have kids!!
The trumpet is a light press fit into the cone. Just pull that out. The cone seems to also be some sort of press fit into the subframe tower. Where you can see the cone on the sides, give it a light tap with a soft hammer and it should drop down.
All this is relevant if you have removed the upper control arm though.... :?
Author:  gafmo [ Thu Nov 11, 2004 8:42 am ]
Never a stupid question unless you ask it many times...Blond
Rears come out easy..Front you only need the cone compresser to undo it all unless it out of the car..but other wise give it a couple of waks with a hammer no need for BFH and a screw driver :lol:
Author:  kazjim [ Thu Nov 11, 2004 9:00 am ]
"The trumpet is a light press fit into the cone" ......
And what colour is the sky in YOUR world ? :wink:
so far i've had to smash the front two and one rear to get them un-stuck !
Luckilly i had the worlds largest supply of cones to choose from !
J
Author:  Wombat [ Thu Nov 11, 2004 9:16 am ]
It's all relative to your preconvieved idea of light medium heavy and won't budge :wink:
When you have been working on Minis for any length of time you perception changes
Author:  J_A_M [ Thu Nov 11, 2004 9:21 am ]
:lol: ....I must have just been lucky. All of mine were "a light press fit"...even the 5 mini's we ratted at Pick and Paylots :D
Author:  minstar [ Thu Nov 11, 2004 9:24 am ]
Post subject:  Yeah so basically
Yeah they're flapping around in the cone towers with the trumpets attached so a light (perception again) tap and they'll drop out . Yeah I have the upper arms out. Is there a trick to getting the trumpets off as I am going hi-los? Or is it likely that they will be MIA in the process...
Author:  Rising Star [ Thu Nov 11, 2004 10:49 am ]
ok
odly enough you ask this question because i put hi-los in my front subframe and checked how hard the rears are to put in
my front subframe was out of the car so it made it easier
all i did with the front ones as i don't have a cone compressor and all my pits had been recently replaced so they weren't sagged (giving more play)
is take the top suspension arm out very simple if the frame is out of the car
no idea if its still in the car but just the 2 bolts (one either side if the arm)
then on one side there is a plate held on by 2 smaller bolts
undo that then slide the pivot rod out then pull of the arm and the rest should come out
if fitting hi-los i was able to put mine back together without the hi-los in it then just wind them all the way in sit them in then wind it back up
hope this helps
rears just undo shockie and jack up car and they should fall out
Author:  minstar [ Thu Nov 11, 2004 11:15 am ]
Post subject:  Ahhh
Yeah I have already removed the top arms. But I wondered if you could install the front HiLos without a cone compressor? Is that what your saying :?: that will come in very handy.... :twisted:
Cheers Rising Star
M
