It is currently Sat Jul 26, 2025 12:55 am
PostPosted: Tue Jan 30, 2007 2:13 pm
Got a big leak from the diff where the shaft comes out on the passenger side.
After studing the an exploded diff diagram the only gasket I cam see on the end cover. Is there a seal in the end covers?
A big leek
PostPosted: Tue Jan 30, 2007 2:14 pm
Yes there is the gasket and there is a seal that the output shaft runs in, they can leak too.
PostPosted: Tue Jan 30, 2007 2:16 pm
I think your problem is vegetable uni's.
Is it leaking from the shafts or somewhere else?
PostPosted: Tue Jan 30, 2007 2:18 pm
Yes , what type of inner joint does the moke have (you'll need to order it to suit the appropriate type , I think they're different) ? Regardless of type there is a seal that fits around the shaft of the cv or rubber uni/hardy spicer yoke and you need to take the drive shaft out to replace it . It's easily done with the engine in situ though , just seperate the ball jounts on the offending side and pull the driveshaft out of the yoke and remove the yoke or jemmy the cv off the diff shaft . Then remove the old seal etc .
PostPosted: Tue Jan 30, 2007 2:19 pm
at the shaft output from the diff on the passenger side. I will get a better idea when all the oil runs out :wink:
The volume of the leak suggests a seal rather than a gasket
PostPosted: Tue Jan 30, 2007 2:22 pm
Oil seal is the same for pot joint and rubber cross uni but different for Cooper S hardy spicer.
PostPosted: Tue Jan 30, 2007 2:28 pm
its a rubber cross uni. Thanks
PostPosted: Tue Jan 30, 2007 3:06 pm
Not the problem. The leak is coming from the block to sump/gearbox mating. So eithe rthe gasket has gone :cry: or loose bolts (I hope).
The oil was running down the gearbox and diff and over the shaft outputs making it look like the the diff seals were leaking.
PostPosted: Tue Jan 30, 2007 3:24 pm
Try checking the bolts. Mine did this and there was a whole bolt missing! :shock: Previous owners! :evil:
Otherwise it could be the diff oil seal which means driveshaft off...
Lillee - 1969 Morris Mini K
PostPosted: Tue Jan 30, 2007 3:33 pm
Yeah , tighten the bolts again and then check to see your engine breaters aren't blocked up as well .
PostPosted: Tue Jan 30, 2007 4:09 pm
Those seals (and both crank seals) tend to go go hard & leak if the engine hasn't been running for quite a while. Good idea to replace them before putting the engine back in :idea:
Been there, done that.
PostPosted: Tue Jan 30, 2007 4:17 pm
not the seals nor the gasket between the block and gearbox. Its the tappet covers, no gaskets and what are the implications of the breather being closed up.
PostPosted: Tue Jan 30, 2007 4:24 pm
OK , you mean the two inspection type plates at the rear of the motor near the fuel pump rather than the tappet cover on top of the motor ? There should be a cork gasket under each one but they tend to fall apart when old . As for the breathers , if they are blocked , older motors can build excess pressure in the crankcase and push the oil out anywhere with an old seal/gasket that's under the oil level or regularly splashed .
 Post subject: Ewwww
PostPosted: Tue Jan 30, 2007 4:28 pm
You may get away with just tightening up all the gearbox bolts....hopefully the O Ring has been put in...do you know ifyou have oil pressure :?:
PostPosted: Tue Jan 30, 2007 4:29 pm
yep the pushrod imspection plate is what I mean. The volume of oil tends to indicate that it needs the breather. So I will add some new gaskets and unblock the breather and give it a whirl. Thanks
Users browsing this forum: Bing [Bot] and 92 guests
