gearbox problems https://www.ausmini.com/forums/viewtopic.php?f=2&t=27925 |
Page 1 of 2 |
Author: | tinymorris1969 [ Sun Feb 11, 2007 11:00 am ] |
Post subject: | gearbox problems |
juz jumped in the mini this morning for a lil drive and found that not only is my second gear crunching whne down gearing but now my third gear the engine shakes for a few seconds i thought it may be the clutch but it never did it before so its wierd for it to be an overnight thing. any help? |
Author: | 1360 LS [ Sun Feb 11, 2007 11:23 am ] |
Is it slipping as well as crunching? If so then I'd look at the seal. ![]() as for the shaking well I'd be taking a look at your engine mounts and making sure they're properly secured. |
Author: | tinymorris1969 [ Sun Feb 11, 2007 11:33 am ] |
well i noticed that if u give it a rev it will slide into gear without crunching and i also noticed that the nut that that connect the push rod to the clutch housing may be loose |
Author: | wild_willy [ Sun Feb 11, 2007 12:18 pm ] |
Most likely clutch hydraulics need attention. Would explain why it happened overnight - air has got into the system. Hope this helps |
Author: | sports850 [ Sun Feb 11, 2007 12:20 pm ] |
Bleed and adjust the clutch and see if it makes any difference , also look for fluid leaks around the master cylinder (and up under the dash where the clutch pedal joins the master cylinder) and the slave cylinder . How's your mechanical knowledge , can you do these things yourself or will you need to take it to a mechanic ? |
Author: | tinymorris1969 [ Sun Feb 11, 2007 1:32 pm ] |
i am a mechanic 3rd yr apprentice actually but im only juz learning about minis |
Author: | sports850 [ Sun Feb 11, 2007 1:36 pm ] |
Ok , well bleed the clutch (check the fluid level as well) and adjust it as per the manual and see how it's going then . |
Author: | tinymorris1969 [ Sun Feb 11, 2007 1:41 pm ] |
ok easy enough with one tiny problem... i dont have a manual |
Author: | sports850 [ Sun Feb 11, 2007 1:43 pm ] |
Well , if you're going to play with mini's you'd better go out and get one , or borrow one from work , they are simple cars but some things without the manual will leave you on the verge of a mental breakdown . |
Author: | tinymorris1969 [ Sun Feb 11, 2007 1:46 pm ] |
yeah i gotta try and find one, a friend said he may have one so fingers crossed also another question if a mini isnt in the best condition is it best not to go out on cruises? |
Author: | Hanra [ Sun Feb 11, 2007 1:52 pm ] |
tinymorris1969 wrote: also another question if a mini isnt in the best condition is it best not to go out on cruises?
I would drive the car no matter what the problems, but make sure u remove all but 1 wheel nut from all four wheels b4 u go. Make sure that last wheel nut on each wheel is only done up finger tight. That way even if there is other problems with the car, all the wheels will fall off at 100klm and then u wont have any more problems to deal with. Except for making sure u have a wil organised b4 u go on ur cruise. |
Author: | tinymorris1969 [ Sun Feb 11, 2007 1:56 pm ] |
haha |
Author: | Hanra [ Sun Feb 11, 2007 1:57 pm ] |
tinymorris1969 wrote: juz jumped in the mini this morning for a lil drive tinymorris1969 wrote: but i can check the clearance and everything when i get it back, its gone for a respray
Wats the go here bud.......? 1st u say u went for a lil drive this morn. Then in another post ur telling me that car has gone for a respray? Are u the full quid? |
Author: | tinymorris1969 [ Sun Feb 11, 2007 1:58 pm ] |
yeah i jumped in this morning for a run and droped it off at my mates to get sprayed |
Author: | bubbos [ Sun Feb 11, 2007 5:14 pm ] |
Post subject: | HI |
HI there don't let them get to you ok they can be a wee bit sassy on here. But really are a nice lot most of the time. ![]() |
