It is currently Fri Jul 18, 2025 10:42 pm
 Post subject: Just got my paint etc...
PostPosted: Sat Feb 10, 2007 2:58 pm
Just got myself the stuff I need to get my a$$ into gear to paint my mini...
I Got
    4L Monza Red Acrylic Paint
    4L Primer
    4L Thinnners
    2 Spray Guns
    50 120 grit discs
    50 180 grit discs
Now to borrow an air compressor and a pneumatic orbital sander.
Will take many pictures along the way...
Cheers Ian
Ian - My Ve SSV Ute - Looking for a Mini
PostPosted: Sat Feb 10, 2007 3:03 pm
good stuff ...
how good of a painter are you?
are you doing underneath the car or jus the outside?
'94 Honda EG4 Civic. -Daily-
'95 Honda DC2 Integra
PostPosted: Sat Feb 10, 2007 3:11 pm
good on ya ian,
if this is your first time, enjoy the ride! id tend to get 25 240 grit discs as well, especially as you are not primer-fill"ing.
cant wait for the results 8)
PostPosted: Sat Feb 10, 2007 3:13 pm
make sure you get it straight first with a board file or bog file as some pl call it
good luck mate, remember advice is only a click away
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Sat Feb 10, 2007 3:15 pm
Just doing what you see basically, yeah first time at giving it ago....
PostPosted: Sat Feb 10, 2007 3:16 pm
what is the board file?? All panel work is straight and has good lines so should be ok....
PostPosted: Sat Feb 10, 2007 3:38 pm
No need for a board file as you won't be doing panel repairs. But yes, you will definately need 240 discs. To get your primer nice and smooth. I finish off primed surface with 340 wet and dry as this will help show deformations in your foundation. Use lemon jif in a bucket of warm water as it will remove any impurities before you start with laquer.
Prepsol your shell before you try sanding the car, that way you will be sure that any silicon based polishes will not creep up on you and bite ur arse. Silicon=painters worst nightmare!!
Your gonna have fun doing this... :wink:
PostPosted: Sat Feb 10, 2007 4:05 pm
On my primer it says Mixing Ratio Primer:100 Thinner :100 is that just the same as 1 to 1.
Would you all recommend mixing it as i do in the paint gun pot or mix a big lot up?
PostPosted: Sat Feb 10, 2007 4:06 pm
YoungMiniac, Did you check with our resident paint guru??
blokeinamoke wrote:
PostPosted: Sat Feb 10, 2007 4:11 pm
After it's all painted get some 1500 and 2000 wet and dry and cut it till it's smooth. (if you get runs and orange peel which you probably will, I didn't get any runs when I painted mine, but tons of orange peel!) Then a cut and polish followed by a nice buff, should look a million dollars!
PostPosted: Sat Feb 10, 2007 4:13 pm
Whos this?
PostPosted: Sat Feb 10, 2007 5:25 pm
Before sanding to paint the top coats on my car we got an enamel p/pack of black and gave the body the lightest coat ever ie. spray from a metre away and dust it on only. This way when you sand with the fine stuff it will highlight any low spots by leaving the black. Also only used a hard sanding block (rubber I think) as this didn't allow us to sand out the low spots by accident. Found a couple of places to put 1 more coat of primer/filler. :D
Must admit we stopped at 800 grit.
Good luck
PostPosted: Sat Feb 10, 2007 6:53 pm
on the topic of painting prep etc what is the best way to cover over rivet holes in your flares, also wouls you try t get the old paint off before fillin or do it after, also what is the besst way to get paint off plastic, also ........... :?
PostPosted: Sun Feb 11, 2007 12:26 am
Good luck
its called a guide coat mate :wink:
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Sun Feb 11, 2007 12:32 pm
You can buy plastic containers from any good paint places. I got some 1ltr ones from memory. They have measurements and ratios printed on the sides - and lids.
These make life much easier and cleaner. Plus, I always give the paint a good stir before putting in the gun to make sure the thinners are mixed well.
When doing the roof, I found with a gravity fed gun, don't put too much paint in, as it can spill out the top cap / reg. Much easier to have the containers here for a quick top up! (I only mixed 1ltr at a time).
I'd say you need to buy more thinners too - 1:1 + plus primer + cleanup.
I didn't wear gloves, but I'd probs at least get some washing up ones etc, as long as the thinners doesn't eat them. Paint + thinners + skin doesn't mix well - also the extra getting into your blood.
Users browsing this forum: No registered users and 112 guests
