It is currently Sun Aug 03, 2025 4:58 pm
PostPosted: Mon Jan 22, 2007 8:55 pm
As some of you might know im halfway through the floor on my mini and I was interested in what was the best way to protect the floor in my mini.
So the test will involve 4 samples. Each plate has been sanded with 80 grit paper thoroughly cleaned with prepsol and placed on some cardbourd. Since cleaning no plates have been touched so there can be no contamination. No plates had any rust on them what so ever.
This test is purely to test what is the best method to keep rust away. I will spray them with water 4 times a day and hen left to rust..
1 control metal plate ( just a bit of metal sanded and cleaned of contaminates)
2 Metal plate treated with metal conditioner as per instructions
3 Metal plate treated with rust converter as per instructions
4 metal plate treated with metal conditioner and rust converter as per instructions.
Lets see which plate has the least amount of rust on it after a few days.
Let the rusting begin
Mike
If it cant be fixed with a hammer it cant be FIXED!!
PostPosted: Tue Jan 23, 2007 7:32 am
are they rusty yet ?????
How about now?
What about now?
or...........NOW?
sorry
PostPosted: Tue Jan 23, 2007 10:23 am
Love the idea Mike, I guess you could also try this out with a few old wives tales as well and see if they really do or don't work.
If you had access to a time lapse camera it would be interesting to see how the different metals reacted and how quickly.
Keep us posted!!
PostPosted: Wed Jan 24, 2007 7:29 pm
Ok here are some pics of the test.
Starting from left to right. 1# Plain metal nothing on it or treating it, this one is tthe control metal tab or the test metal tab. 2# The next one has metal conditioner on it. It should still rust but not as much. 3# The next one has a rust converter on it. Yoou spray it on and leave it, you are then meant to clean the black stuff off with water. Not sure about this one, maybe the black stuff that is coating the metal will protect it from rust maybe not.. 4# The next on has mettal conditioner and rust converter. Same as the 3rd one not sure what will happen here.
Im going to leave them till there is clear visable rust on tab #1 Then I will clean the black stuff off the other two tabs.
Day one
There is already rust on tab #1 up the top left corner near that weld. Im suspecting water is pooling here.. We still need more rust though.
Day two
I will take another pic tomorrow..
Mike
PostPosted: Wed Jan 24, 2007 7:44 pm
great idea Mike.
i take it you only painted the top surface of the treated ones? if so, don't forget to turn them over at the end of the test to see what the reverse side of each looks like....
michael
PostPosted: Wed Jan 24, 2007 7:49 pm
doing it all in the name of science...well...mini preservation anyhow :wink:
ook!
69 mini k
PostPosted: Thu Jan 25, 2007 10:12 am
are you using a deoxidine treatment on any mate?
PostPosted: Thu Jan 25, 2007 12:38 pm
Your metal pieces look too clean. The rust converters need rust to convert :roll: Should have at least surface rust to start with - won't work on clean metal.
David L
PostPosted: Thu Jan 25, 2007 12:45 pm
It depends on the product. If it is a matter of protection of the metal, then a deoxidine treatment does not necessarily need rust. so long as the surface is clearn from grease and dirt, once you apply the treatment, it creates a chemical transformation and bronzez the metal to protect it from rust in the future...
But for rust converters youre correct you do need rust.
PostPosted: Thu Jan 25, 2007 4:42 pm
Yes but the idea in this experiment is to protect the meal from rust.. Im not interested in converting rust... If the metal is left to the elements water rain sun heat it should rust, Yes? Well lets see if the poducts can stop that from happening in the first place..
If we are talking about converting the rust the metal conditioner wins hands down.. You put it on and as you wipe the metal you really can see the surface rust disolve.. I will post some pics of this next week.
Mike
PostPosted: Thu Jan 25, 2007 4:45 pm
Ok today I was rather anoyed that I still dont realy have any noticable surface rust on the metal tabs yet not even the untreaeted one... GGGRRRR.. So needless to say I couldnt be bottherd taking a pic as it looks the same as yesterday.. I have even been hosing the liveing crap out of them and still not rust... Anyway I will leve them over the long weekend and come monday there maybe some change.
Mike
PostPosted: Thu Jan 25, 2007 6:59 pm
Spray an even amount of water over each of them to speed up the process :lol:
PostPosted: Thu Jan 25, 2007 8:10 pm
I have sprayed heaps on it... Hosed it
PostPosted: Tue Feb 13, 2007 4:58 pm
ok here is a update... There not rusting as fast as I thought they would.. Im thinking as they havent been touched at all.. They are just sitting on a shelf outside where they can get rained on or hosed......
This is week 2 I think
And this would be week 3
I will take another pic this week
Mike
PostPosted: Tue Feb 13, 2007 5:13 pm
Are they in the sun? If they are, maybe they are drying out too quick!!!
Steve
