fuel cap
https://www.ausmini.com/forums/viewtopic.php?f=2&t=27937
Page 1 of 3
Author:  tinymorris1969 [ Sun Feb 11, 2007 2:09 pm ]
Post subject:  fuel cap
does anyone know how to stop fuel tipping out of the tank, ive recently taken off the cap and replaced it with a key lock cap, still leaks petrol and i do a right turn but
Author:  Hanra [ Sun Feb 11, 2007 2:12 pm ]
Most people simply stop turning right to solve this problem. If they need to go right, they take 3 lefts and that gets them going in the correct direction. Try it, really works.
Author:  steve1965 [ Sun Feb 11, 2007 2:36 pm ]
Post subject:  Fuel Cap
The only way to stop it is to buy a locking fuel cap from the uk they don't leak.
Steve
:D
Author:  Mike_Byron [ Sun Feb 11, 2007 2:37 pm ]
Hahaha - hanra
Okay - I have been through this many times over the years - simply, the best caps are the original non lockable caps supplied by the factory and then replace them as the seal begins to wear.
The second trick is not to squeeze the absolute maximum amount of fuel into the tank. Stick the petrol filler spout right down the neck of the tank and stop filling the tank the first time the pump clicks off.
Author:  tinymorris1969 [ Sun Feb 11, 2007 2:39 pm ]
yeah i did that hmmm i mite try and find a seal for the old cap
Author:  sports850 [ Sun Feb 11, 2007 2:58 pm ]
Easiest way is like Mike said , don't try and fit too much in , remember the top of the tank is right at the filler so put the bowser nozzle all the way in and only fill it to the first click (bowser cutout click) and you will have to go really fast around a right hand bend to make it leak .
Author:  tinymorris1969 [ Sun Feb 11, 2007 3:28 pm ]
hmmm i tryed that and it still seeps out im trying to get a picture of the damage of it
Author:  Hanra [ Sun Feb 11, 2007 3:35 pm ]
Maybe theres a hole in ur fuel cap dear lizza, dear lizza?
Author:  tinymorris1969 [ Sun Feb 11, 2007 3:37 pm ]
nah man i think its got to do with the seal
Author:  gafmo [ Sun Feb 11, 2007 3:51 pm ]
:lol: never thought of that
Author:  1018cc [ Sun Feb 11, 2007 5:01 pm ]
Maybe you could just put a fuel cell in and be done with it.....but then there would be problems with venting it.......
Author:  buztoy [ Sun Feb 11, 2007 5:08 pm ]
i was looking at the rover tanks and they have a little clicky thing on them and the one way valve, can you change the necks over,
Author:  sports850 [ Sun Feb 11, 2007 5:11 pm ]
No , neck is welded to the tank and I think the flappy thing needs the rover neck to mount on . Another point though is to make sure the flat of the neck that the cap seals on is flat and smooth , i.e, no gouges in the paint that will stop the seal from working and no dents that will do the same thing .
Author:  Mini Mad [ Sun Feb 11, 2007 8:44 pm ]
The 'Aston' caps seal pretty well, me an Hanra have the same one and it seals pretty good. about $70 i think though..
Author:  Hanra [ Sun Feb 11, 2007 9:20 pm ]
This style!!! Gee they look good, but ive still found if i fill up to much, they still leak.......mungral! Seems to leak at the top most point of the cap? But i just stick to putting a few dollars worth of BP Ultimate in at a time.
Page 1 of 3 All times are UTC + 10 hours
