1100 sport https://www.ausmini.com/forums/viewtopic.php?f=2&t=27943 |
Author: | tinymorris1969 [ Sun Feb 11, 2007 4:40 pm ] |
Post subject: | 1100 sport |
did the mini 1100 sports come with a front spoiler as standard cause mine has and looks like it is standard, not sure juz wondering |
Author: | sports850 [ Sun Feb 11, 2007 4:43 pm ] |
That may be a bit hard to answer as there wasn't an 1100 sport produced by the factory , I'd suggest it's been someones custom work or a dealer modified car , what is the number on the plate on the firewall , the one that say's car type ? As for the spoiler , no Australian produced mini's had a front spoiler as standard . |
Author: | tinymorris1969 [ Sun Feb 11, 2007 4:45 pm ] |
u reckon it could be an import cause its badge says mini sport 1100 and as for the body plate well its worn away cause the writing is so hard to see |
Author: | sports850 [ Sun Feb 11, 2007 4:56 pm ] |
No , looking at your photo's in the members gallery it looks like an Australian produced mini K (had the 1100 motor standard) according to the bonnet badge . If the boot badge says 1100 sport then it's likely to be an English badge of some form added by a previous owner . I'm not sure of the badge's origin , somebody else with experience with the UK mini's might recognise the 1100 sport badge . The car type number on the plate will confirm what model it is . |
Author: | tinymorris1969 [ Sun Feb 11, 2007 5:57 pm ] |
hmmm well ill have another look at the car body plate but like i said i cant find it in its usual spot (under the driver side bonnect hinge) so it must have worn off or been rubed out |
Author: | simon k [ Sun Feb 11, 2007 6:07 pm ] |
probably a home-made badge - just using a clubman badge surround with a home-made insert. Or might be from a UK model The body is Australian production (LH parking wipers and ext. door hinges), it's a custom dash with all those guages etc. being a K, theres a good chance there was no ID plate installed from the factory - inbetween when the ID plate was deleted, and the ADR plate came in... what's the number stamped on the radiator shroud? |
Author: | sports850 [ Sun Feb 11, 2007 6:31 pm ] |
With mini's of that age , the id plate will most likely be on the firewall behind the master cylinders , could be behind a sound deadener blanket . |
Author: | tinymorris1969 [ Sun Feb 11, 2007 9:09 pm ] |
yeah i check and like i said it must be worn out or something cause its hard to read and ill take a pic of the badge in the back and u guys can tell me, by the looks of it it seems like its original to the car but im not sure |
