ignition switch wiring
https://www.ausmini.com/forums/viewtopic.php?f=2&t=27955
Author:  buztoy [ Sun Feb 11, 2007 7:28 pm ]
Post subject:  ignition switch wiring
hey
just a quick one, does the wiring for the ignition for the starter and wiring go:
red and white wire carry a pos+ charge to the starter solinoid,
white and blue wire carry a pos+ charge to the coil
and the ignition switch does not have any internal grounding, cawz its a blip in my diagram and does'nt document it
Author:  Mike [ Sun Feb 11, 2007 7:42 pm ]
The ignition switch doesnt have any grounding as its just a switch between a constant +12v to the fuse box's "on on ignition side" and to the coil in its first position and to the starter motor solenoid in its second position.
So it has a thick (brown?) input cable which is a constant +12v and two output terminals:
1st (this terminal links to the input +12 when you turn the ignition switch to its 1st position) terminal: to the coil's positive side (just check what wire colour connects to the positive side of the coil and then locate the same wire next to the ign. switch. And a thick white wire to the "on on ignition" half of the fuse box (for stuff like wipers etc).
2nd terminal (this terminal only links to the +12v input when the ign. switch is in its last, "cranking" position): a thin red/white wire to the starter solenoid.
Author:  buztoy [ Sun Feb 11, 2007 8:04 pm ]
just wanted to check before i cranked it over, i have'nt fused anything yet :wink:
thanks mike
Author:  Morris 1100 [ Sun Feb 11, 2007 8:12 pm ]
Keep trying, I am sure if you can do it if just put your mind to it. :lol:
Author:  Blokeinamoke [ Sun Feb 11, 2007 8:13 pm ]
fuses - who has fuses - just through a couple of nails in there and can save all that money on fuses :wink:
Author:  Hanra [ Sun Feb 11, 2007 8:25 pm ]
Nails blow at 120amps. I think mini wiring is probably rated to maybe 60-70amps. At least the nails will stay in good condition. Can never have to many good nails these days.
Author:  Blokeinamoke [ Sun Feb 11, 2007 8:32 pm ]
I bet you say that to all the girls.........
Author:  Hanra [ Sun Feb 11, 2007 8:33 pm ]
Hahahahahahahahahaha!!!!!
