needle type?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=27991
Author:  68matic [ Mon Feb 12, 2007 7:57 pm ]
Post subject:  needle type?
Hi, can anyone suggest a needle for the following engine specs:
newish
1132cc
mild cam grind
head ported and skimmed just a little
1.5SU
for daily moke
currently running a floating needle (not what i want)
fuel economy isnt very economic too :!:
schmanks!
Author:  ss wanab [ Mon Feb 12, 2007 8:53 pm ]
e3 fixed needle is what i run mine needs it so it can run bit richer for some reason
see if u can catch someone with vizards book has all the specs n needle codes in there 8)
helped in choosing my setup :D
Author:  Hanra [ Mon Feb 12, 2007 8:56 pm ]
http://www.mintylamb.co.uk/suneedle/
http://www.teglerizer.com/cgi-bin/needle090db.cgi
Have fun choosing!!!
Author:  68matic [ Mon Feb 12, 2007 9:24 pm ]
:oops: gee i dont know how to use those sites
can anyone say "get this:..."?
Author:  AEG163job [ Tue Feb 13, 2007 8:33 am ]
If only it were that easy :lol:
OK, the swinging needle you have has probably worn the jet, hence :cry: fuel consumption. recommend you get the CZ fixed needle & conversion bush, (about $20) and replace the jet. The spring loaded needle (ABP?) - chuck it severely.
This should restore fuel consumption to reasonable level, however to get optimum consumption & performance you should consider dyno tune. As usual, it all comes down to how much you want to pay :wink:
As for fuel consumption generally, Clarkson's stint in the Bugatti Veyron l(Top Gear last nite) puts it into perspective!
Author:  68matic [ Tue Feb 13, 2007 10:12 am ]
thanks pete :wink:
