Plating bolts
https://www.ausmini.com/forums/viewtopic.php?f=2&t=28069
Page 1 of 3
Author:  GT [ Wed Feb 14, 2007 8:57 am ]
Post subject:  Plating bolts
I want to get ALL the bolts from my GT plated.
I think Doogie once told me you can get a bucket of bolts plated quite cheaply.
Is it CAD plate that gives that clean dull yellow-ish finish to bolts?
Anyone in Sydney had this done? If so, how much?
Thanks.
Author:  Mick [ Wed Feb 14, 2007 9:06 am ]
Not in sydney but...
I had this done, a whole bucket full of bolts, nuts, washers, springs, brackets, door bits, you name it it was in the bucket. Cost me 30 dollars on an off peak deal. You would pay someone to do that just for the grease removal alone I reckon. The bolts are brand new and look it.
The gold colour you are referring to is still zinc plating, a small amount of copper is added to the zinc to create this colour. For your small amount of money, they will dip the entire lot in acid to remove grease, oil dirt and old rust and coatings and then zinc plate. Takes about a day. Ask them to please please not lose any screws, they sometimes can fall through the sieves they lower them into the bath in. Nylocs will surviv the process just fine.
Not recommended for hi tensile engine bolts use as apparently they can lose their tensile strength a little. I did have the general engine bolts and nuts done and had no problems when I did use them. Springs thrown into the bucket will need to be fished out after and roasted in the oven with the sunday lamb for an hour or so at 200 to normalise the spring.
CAD plating has fallen a little out of favour because of the cadmium involved is rather nasty testicular tissue destruction, renal failure etc
Author:  willy [ Wed Feb 14, 2007 9:11 am ]
Yes you'll find that most places will Zinc plate your bits.
As Mick said - count EVERYTHING that you send away!
:lol:
Author:  GT [ Wed Feb 14, 2007 9:20 am ]
will the zinc plate 'break off' when you turn a ring spanner tightly on a bolt head?
I have seen this happen with chrome and nickel plate.
Author:  Mick [ Wed Feb 14, 2007 9:23 am ]
No it rubs off over time slowly if you keep doing it up and undoing it, depending on the application thickness. No difference to original.
Looks absolutely amazing and is the small part of the job that brings a huge amount of satisfaction.
Author:  mickmini [ Wed Feb 14, 2007 6:36 pm ]
it is nickel plating not zinc that gives the goldy colour
and cadmium is only a problem if you sand, grind, cut or burn it and breathe the dust or fumes. its carcenogenic....
michael
Author:  graham in aus [ Wed Feb 14, 2007 6:48 pm ]
Actually to get technical, the gold colour on zinc and cad plating is called 'passivating' and it makes the surface less susceptible to corrosion, a zinc plated bolt will show white powdery corrosion if not pasivated.
As has been said, Cadmiun has pretty much been outlawed on OH&S issues..... very poisonous.
Nickel is another matter entirely, more expensive and yes, a bit of a yellow (light gold) colour. Normally part of the chroming process, Copper, Nickel then a very thin layer of chrome. Nickel helps fill imperfections / polishing.
Having said that; a lot of old British bikes used Nickel as the final finish, it is a nice look, but expensive! 8)
Author:  drmini in aust [ Wed Feb 14, 2007 6:58 pm ]
I have a small zinc plating bath and also a nickel one. The zinc one is already up and running, but it's tedious work doing lots of small stuff.
The nickel one will work once I source a small, cheap heater (needs to run at 50-60C). :wink:
Author:  Morris 1100 [ Wed Feb 14, 2007 7:03 pm ]
Like a submersible heater?
Author:  drmini in aust [ Wed Feb 14, 2007 7:07 pm ]
Yeah, someone said maybe a tropical fish tank one might work? dunno their temp though..
It's only a 3L plastic container, so needs to be small.
Author:  Morris 1100 [ Wed Feb 14, 2007 7:15 pm ]
An electric kettle and a thermostat. 8)
I might be able to find a small heating element with a thermostat, I would have to look at the temp range. I know it works at about 20 to 30c, I would just have to see how high it goes. :wink:
Author:  drmini in aust [ Wed Feb 14, 2007 7:20 pm ]
I could use a Rheem water heater one and adj thermostat, but they are way too big for the container.
and I think even a 1.8KW would be overkill... :lol:
Author:  Morris 1100 [ Wed Feb 14, 2007 7:32 pm ]
The problem is not the size of the heater, it is the size of the tank. Think big.
Now, would there be a market for plated sub-frames? 8)
Author:  drmini in aust [ Wed Feb 14, 2007 7:51 pm ]
One of the eternal mysteries in UK is, WHY didn't BMC hot dip gal the bloody things... :?
:idea: then connect electrically to the body, and you have a sacrificial anode in wet weather! :lol:
Author:  Morris 1100 [ Wed Feb 14, 2007 7:54 pm ]
I think that in England the rear sub-frame is the sacrificial anode.
I have a lot of fun telling the poms and yanks that the sub-frames in Australian 1100's don't rust.
Page 1 of 3 All times are UTC + 10 hours
