It is currently Sat Jul 19, 2025 3:41 am
PostPosted: Sat Nov 13, 2004 5:48 pm
Wiffy just got home and Morris was not sounding correct at all.
It had only just started around the corner from home...
All looks well except a very strang Tak Tak Tak sound with the rev's and idle coming from number 4 side :cry: its not the tappets..
Idea Guys
PostPosted: Sat Nov 13, 2004 6:03 pm
Are you sure it's not the tappets.. I had one go bad on my son's Clubbie, turned out to be one dud late model POS sintered rocker..
I just took another one off the pile in the corner- now it's fine again! :lol:
If you think the problem is further down, pull the plug leads off one at a time- to see which cylinder.
PostPosted: Sat Nov 13, 2004 6:21 pm
Is it running ok other than the noise. i would hate to think it being a serious problem like dropping a valve seat or the like. Just an idea but is the manifolds all nice and tight, could be a something round there. It's hard to say.
Aaron
PostPosted: Sat Nov 13, 2004 6:25 pm
I dont think its the tappets.
Spark plugs ...(useing Spare plug)..on all cylinders wont spark unless it is able to jump between an earth (body)
I have checked all earths Battery and body to engine :?:
PostPosted: Sat Nov 13, 2004 6:27 pm
Idea Guys
Blown manifold gasket?
Chris
Everything I like is either
I mean just pull each lead off in turn- it will miss- see if the noise goes away. That will tell you which cylinder.
Tighten all the manifold nuts- they usually come loose a week after assembly... :shock:
PostPosted: Sat Nov 13, 2004 6:45 pm
Stuff it it can wait till I come back. :cry:
Cheers Thanks
Users browsing this forum: No registered users and 112 guests
