Sump Bolt https://www.ausmini.com/forums/viewtopic.php?f=2&t=28193 |
Page 1 of 2 |
Author: | Blokeinamoke [ Sat Feb 17, 2007 1:33 pm ] |
Post subject: | Sump Bolt |
Is the sump bolt alloy or steel? Is there a an expansion difference between the bolt and the sump case when warm? I have have got the sump case warm the oil warm and she no wanto come? Any suggestions? |
Author: | Mick [ Sat Feb 17, 2007 1:36 pm ] |
Well magnets stick to it...it's at least ferrous. Anyway, isn't steel an alloy? |
Author: | slinkey inc [ Sat Feb 17, 2007 1:45 pm ] |
Not really. Iron is the element. Steel is mostly Ferrous (Iron II) but with some extra including (Iron III, the ion of tha tis rust). So I guess you could say it is an Alloy, but really for the sake of it, it's not, it's really Iron. |
Author: | 9YaTaH [ Sat Feb 17, 2007 2:44 pm ] |
Post subject: | Crack It |
Have you tried turning it anti-clockwise?? |
Author: | Blokeinamoke [ Sat Feb 17, 2007 3:35 pm ] |
Post subject: | Re: Crack It |
9YaTaH wrote: Have you tried turning it anti-clockwise??
um ...yes..derr ![]() I using a pipe wrench. The problem is TPO has used a cold chisel on it. So I have nothing to grip on. The bolt is completely mangled. Maybe I should be clearer. Any sugesstions on how to remove a magled sump bolt? |
Author: | Mick [ Sat Feb 17, 2007 3:43 pm ] |
We just went through this last night on another thread. But it looks like you may have to resort to the cold chisel as well and replace it. http://www.ausmini.com/forums/viewtopic ... col+chisel Once the chisel has touched it, it's usually useless for anything else. |
Author: | BOB1275 [ Sat Feb 17, 2007 4:33 pm ] |
get one of thoses screw removers you drill a hole in the centre then screw in the tool then screw it out and the bolt should come with it iv used them a few time they work pretty good cheers bob |
Author: | tinymorris1969 [ Sat Feb 17, 2007 5:01 pm ] |
get a set of vice grips on it and use them they are guarrented to work or ur money back |
Author: | sports850 [ Sat Feb 17, 2007 5:07 pm ] |
If it's not working with a pipe wrench/stilsons which has a longer handle than a pair of vice grips then I doubt vice grips will budge it . Stephen , if all else fails , try an easy out as BOB1275 suggested or even weld (short bursts so as to not build up too much heat) a nut onto the end of it . Have you put the stilsons on it and put a jack under the end and left it sitting with pressure on it for a while , might help persuade it to come loose ... |
Author: | 9YaTaH [ Sat Feb 17, 2007 5:27 pm ] |
Post subject: | Magled=Mangled |
Is there enough meat left to file a couple of flats for a large open ender ![]() Drilling it could be harder than what you think....what happens when you get through the soft alloy head and hit the magnet...does it just fall off into the sump ![]() OH...have you tried a little local heat ![]() |
Author: | drmini in aust [ Sat Feb 17, 2007 6:11 pm ] |
Post subject: | Re: Magled=Mangled |
9YaTaH wrote: Is there enough meat left to file a couple of flats for a large open ender
![]() Drilling it could be harder than what you think....what happens when you get through the soft alloy head and hit the magnet...does it just fall off into the sump ![]() OH...have you tried a little local heat ![]() Don't mess about, plug is steel, just get the MIG and weld a socket to it. It'll be off in seconds. ![]() |
Author: | Mick [ Sat Feb 17, 2007 7:08 pm ] |
What's going on? A rash of sump plugs jamming? It's like they've all gone on strike. Anyone remember the movie maximum overdrive? maybe the machines are conspiring against us.... |
Author: | 9YaTaH [ Sat Feb 17, 2007 10:25 pm ] |
Post subject: | Mangled |
drmini in aust wrote: Don't mess about, plug is steel, just get the MIG and weld a socket to it. It'll be off in seconds.
![]() Doc you could also weld a nut on ![]() |
Author: | Mini Mike [ Sat Feb 17, 2007 11:18 pm ] |
As doc ssaid... Go down to super cheap get yourself a cheap socket to fit a larg ratchet preferbly a 1/2 drive rachet (big sucker ratchet) or if you dont have a 1/2 drive ratchet get one for a 3/8 drive Then weld what ever size socket you got onto your sump plug. Plug your ratchet in and it will be offf so quick. By the way I havent tried this and if you do, let us know how it went. Mike |
Author: | mini-dunger [ Sun Feb 18, 2007 12:30 am ] |
Post subject: | Maximum Overdrive |
maximum overdrive was an awesome movie. I think it was a little underated. Plus ACCA DACCA did the sound track! |
