It is currently Wed Jul 23, 2025 2:41 am
 Post subject: cooper s R/tank strap
PostPosted: Sat Feb 17, 2007 4:24 pm
Hi, just wondering if mk 1 right tank strap is spot welded or bolted behind rear seat, cheers.
PostPosted: Sat Feb 17, 2007 4:30 pm
Bolted, but doesn't use normal bolts. They are studs pressed or welded onto ver particular straps to spread the load. If it doesn't have these studs, and the bracket beneath the R/H tank then it's a clever ruse.
PostPosted: Sat Feb 17, 2007 7:10 pm
If you look at the following picture you will see all the parts required for a proper RH tank instal.
The bracket at the bottom left holds the strap to the rear of the seat and is bolted through the 4 holes.
The bracket at the bottom right is the one that is spot welded to the boot floor under the tank.
Regards
Daniel
