Morris sounds like a Dak Dak https://www.ausmini.com/forums/viewtopic.php?f=2&t=2822 |
Author: | gafmo [ Sat Nov 13, 2004 5:48 pm ] |
Post subject: | Morris sounds like a Dak Dak |
Wiffy just got home and Morris was not sounding correct at all. It had only just started around the corner from home... All looks well except a very strang Tak Tak Tak sound with the rev's and idle coming from number 4 side ![]() Idea Guys |
Author: | drmini in aust [ Sat Nov 13, 2004 6:03 pm ] |
Are you sure it's not the tappets.. I had one go bad on my son's Clubbie, turned out to be one dud late model POS sintered rocker.. I just took another one off the pile in the corner- now it's fine again! ![]() If you think the problem is further down, pull the plug leads off one at a time- to see which cylinder. |
Author: | aaron [ Sat Nov 13, 2004 6:21 pm ] |
Is it running ok other than the noise. i would hate to think it being a serious problem like dropping a valve seat or the like. Just an idea but is the manifolds all nice and tight, could be a something round there. It's hard to say. Cheers Aaron |
Author: | gafmo [ Sat Nov 13, 2004 6:25 pm ] |
I dont think its the tappets. Spark plugs ...(useing Spare plug)..on all cylinders wont spark unless it is able to jump between an earth (body) I have checked all earths Battery and body to engine ![]() |
Author: | Chris [ Sat Nov 13, 2004 6:27 pm ] |
Post subject: | Re: Morris sounds like a Dak Dak |
gafmo wrote: Wiffy just got home and Morris was not sounding correct at all.
It had only just started around the corner from home... All looks well except a very strang Tak Tak Tak sound with the rev's and idle coming from number 4 side ![]() Idea Guys Blown manifold gasket? |
Author: | drmini in aust [ Sat Nov 13, 2004 6:27 pm ] |
I mean just pull each lead off in turn- it will miss- see if the noise goes away. That will tell you which cylinder. Tighten all the manifold nuts- they usually come loose a week after assembly... ![]() |
Author: | gafmo [ Sat Nov 13, 2004 6:45 pm ] |
Stuff it it can wait till I come back. ![]() Cheers Thanks |
