Are Grommets made of gold????? https://www.ausmini.com/forums/viewtopic.php?f=2&t=28346 |
Author: | scotta_74 [ Tue Feb 20, 2007 7:54 pm ] |
Post subject: | Are Grommets made of gold????? |
I went in search of some rubber grommets to fill a few holes in the 850 and to replace the origional ones that had perished. Clark Rubber was my first thought but I nearly died when I saw a 15mm grommet was going to cost me $3.15 EACH ![]() There is no way on earth I will be paying $2- $3 a grommet, where else is there that has them for a cheaper rate or can you buy a kit similar to an "O-Ring" kit???? ![]() |
Author: | sports850 [ Tue Feb 20, 2007 7:55 pm ] |
Try a panel beating supply place or an autolec , they normally have them in the multi-size kits for a damn sight less than that . |
Author: | gafmo [ Tue Feb 20, 2007 7:59 pm ] |
Try Grippy Rubber 253 Victoria Road Rydalmere - 9898 9688 You know the bridge that goes over the railway line just after the Uni at North Parra. As you coming over the Crest take the first left and the left under the bridge then left again Not sure on the prices but they will have every thing you want in one store ![]() |
Author: | 1310/71 [ Tue Feb 20, 2007 8:14 pm ] |
If grippy's isn't convenient or whatever, try spectrum rubber in dunheved industrial estate. I seen heater hose in Clark rubber with spectrum stickers on the box so I suspect they supply SOME stuff to clark rubber. I've found them to be reasonably priced over the years. KB |
Author: | Betty [ Wed Feb 21, 2007 12:54 am ] |
Clark rubber are always $$$ i find! You have a PM Scott |
Author: | Hagar [ Wed Feb 21, 2007 7:06 am ] |
Have a look at late model cars next time you're at the wreckers. I found E series (EA, EB etc) Falcons in particular have more grommets than metal, especially around door jambs, under the sills and the boot floor. |
Author: | doogie [ Wed Feb 21, 2007 7:16 am ] |
Scott, here is the list of all rubbers for minis at Scotts old rubber company at Dunhaven, there cheap as chips for grommets there. http://www.scottsoldautorubber.com.au/M ... elyand.htm Doogie |
Author: | 1360 LS [ Wed Feb 21, 2007 7:18 am ] |
ohh didn't you know they were made of gold.... you should see the platinum ones now they are $$$$$ but on a serious note I'd visit the rydalmere one gafmo mentioned I've been there before and got great service, they treated me ok hope they do the same for you |
Author: | 1310/71 [ Wed Feb 21, 2007 2:07 pm ] |
2 S's & a clubman wrote: Scott, here is the list of all rubbers for minis at Scotts old rubber company at Dunhaven, there cheap as chips for grommets there.
http://www.scottsoldautorubber.com.au/M ... elyand.htm Doogie The place in Sydney was called Peter Jackson's Old Rubber Company, now called spectrum rubber following an employee buyout. It's the same place I recommended to you in an earlier post. Not sure of the previous or current tie-in with Scotts. KB |
Author: | Steve.E [ Wed Feb 21, 2007 4:57 pm ] |
Peter Jackson owned Spectrum untill the marrige ended then had old rubber company but Pete and Bev are moving down south and will be harder to get stuff from. Pete does or did fantastic parties Steve |
Author: | scotta_74 [ Wed Feb 21, 2007 8:22 pm ] |
Thanks for the replies guys, much appreciated. ![]() |
Author: | 1310/71 [ Wed Feb 21, 2007 8:57 pm ] |
Steve.E wrote: Peter Jackson owned Spectrum untill the marrige ended then had old rubber company but Pete and Bev are moving down south and will be harder to get stuff from.
Pete does or did fantastic parties Steve When's Pete moving and where to? KB |
Author: | screech [ Wed Feb 21, 2007 9:16 pm ] |
How much should a grommet thingy be?? |
