smoke coming from back of engine when running
https://www.ausmini.com/forums/viewtopic.php?f=2&t=28474
Author:  buztoy [ Sat Feb 24, 2007 1:57 pm ]
Post subject:  smoke coming from back of engine when running
when she is running she blows a bit of smoke out of the back of the engine, i think it could be only of 3 things:
1: the head gasket is blown, (havent had to change one so it will be interesting,
2: it has LCB exstractors and i think one of the connection pipes has a leak.
3: the flange on the exstractors is not porperly lined up with the port from either 2 or 3,
a bit of oil is leaking from in between the block and the head if thats any more help
Author:  buztoy [ Sat Feb 24, 2007 3:29 pm ]
solved :D
tis was the exsaust near the muffler,
moisture was from the condensation, i ran a compssion test and she is fine, 155psi
