Brake piston compression
https://www.ausmini.com/forums/viewtopic.php?f=2&t=28501
Author:  Blokeinamoke [ Sun Feb 25, 2007 8:59 am ]
Post subject:  Brake piston compression
What does everybody use to compress the piston when doing a pad change of a bisc braked car?
Author:  mini_matt [ Sun Feb 25, 2007 9:04 am ]
Post subject:  brake
g clamp is what i use at work
Author:  tinymorris1969 [ Sun Feb 25, 2007 9:58 am ]
go to repco or peps and buy a steering wheel puller they usually work well i use it. or g clamp or a 16" pair of multi grips
Author:  Mick [ Sun Feb 25, 2007 10:43 am ]
I like to use a vice, not because of the brute strength, but because it's got a pair of parallel jaws and can give gentle and consistant pressure. I also use soft jaws and a block of timber to stop any marking.
edit...ops, during a pad change. I didn't read it properly....yeah, in that case multigrips.
Author:  drmini in aust [ Sun Feb 25, 2007 1:24 pm ]
I put 2 flat spanners in between rotor and piston, then lever them apart. Do ONE pad at a time. :wink:
Author:  KLAS [ Sun Feb 25, 2007 8:15 pm ]
i am using this tool
Author:  Blokeinamoke [ Sun Feb 25, 2007 8:18 pm ]
Guter Tag, Klas, das wie ein feines Werkzeug aussieht. Von wo Sie es bestellten
Author:  KLAS [ Sun Feb 25, 2007 8:29 pm ]
Das gibts hier beim örtlichen Motorradteile Laden :wink:
over here you can get this at the local motorbike parts shop
or ebay, is around 20€
Author:  Blokeinamoke [ Sun Feb 25, 2007 8:32 pm ]
viel Dank. Ich halte ein Auge heraus auf ebay für eins. :)
