VicMini13 wrote:
If you want to use the Isolator as a cut out switch too - it needs to go on the positive, and the charge wire from the alternator will have to move to the battery side of the switch, otherwise if you isolate the battery while the engine is running it will continue running on the power supplied from the alternator charge circuit.
This seems a strange advice (or am I not getting something?). To "isolate the battery with the engine running" with one of these switches you'd have to physicaly screw out the knob and remove it while the engine is running. This is a pretty unreasonable thing to do anyway but if you did this the low amperage fuse that bypasses that knob (this is if you indeed set it up with a fuse so as to act like a cut off switch like was suggested before) will either blow because of the drain of the ignition and headlights and then everything will die or if the fuse is higher amperage and the headlights are off then the charging circuit to the battery will be maintained through that fuse.
The idea of the cut off switch on the isolator is that a fuse will power auxilaries with the engine off and the isolator switched off but will burn out when one tries to crank the engine over to start it without screwing the isolator knob back in (as the drain then will burn any fuse thinner than a nail). Not that the fuse will burn with the engine running.
