Low Beam problems.
https://www.ausmini.com/forums/viewtopic.php?f=2&t=28530
Author:  matt850 [ Sun Feb 25, 2007 7:41 pm ]
Post subject:  Low Beam problems.
Dont know if this is a common problem. My "Low Beam lights have just stopped working. Seems too coin cidental that they have both stopped at the same time....unless they are in sequence (or whatever you call it).
Should I be looking to check both globes or is it more likely the dimmer switch???
Thanks in advance as always
Matt
Author:  ryan [ Sun Feb 25, 2007 7:44 pm ]
if you still have high beam, i would be guessing that you have a loose wire somewhere. It could be aat the switch or behind the dash, or it could be a break in the wire somewhere. Highly doubt that its both globes.
Ryan
Author:  drmini in aust [ Sun Feb 25, 2007 8:06 pm ]
Most likely either the dipswitch, or the low beam connector behind the grille is dirty or the blue/red feed wire popped out.. If it's dirty, I'd strip and clean em all. :wink:
Author:  mad-mk1 [ Mon Feb 26, 2007 3:20 pm ]
or get h4s put in 8)
Author:  Mick [ Mon Feb 26, 2007 3:38 pm ]
Are you using a foot or column mounted dipper switch?
Author:  tinymorris1969 [ Mon Feb 26, 2007 5:27 pm ]
ive got the same problem at the moment with my mini, i only juz found that the juntion that all the wires connect to has come loose and also my dimmer switch has S**t itself so on every bump highbeam is activated and i loose the low beam check the wiring if thats fine change ur switch u may even have a bad earth
Author:  Mick [ Mon Feb 26, 2007 5:47 pm ]
Earth is common for both the high beam and low beam on minis. So if H/B is working, then the earth is not at fault.
Author:  Mick [ Mon Feb 26, 2007 5:48 pm ]
The trick is to chase the twelve volts with a multimeter. at both the common blue/red connection behind the grill near the bonnet lock mech. and then at the connections under the steering column inside the cabin. It will point to the problem.
Author:  tinymorris1969 [ Mon Feb 26, 2007 6:15 pm ]
wel i found its the wiring under the dash
Author:  matt850 [ Mon Feb 26, 2007 8:32 pm ]
thanks all, thats a little job for tomorrow.
Author:  matt850 [ Tue Feb 27, 2007 8:22 am ]
Fixed in 30 secs. It was the connector box behind the grille. I love this website. Saves me money everytime I log on.
Cheers all, thanks for your help.
