It is currently Sun Aug 17, 2025 9:41 am
 Post subject: MkII Cooper S 'register'
PostPosted: Mon Feb 26, 2007 4:26 pm
I'm intersted in putting together a list of MkII S chassis and bulkhead numbers. . .not strictly a register (as I know a lot of people dont like to have that sort of info listed in publicly accessible places) just a list of numbers, mainly aimed at seeing if there is any real order to the body vs chassis number difference. . .ie if it does increase from 500 in any meaningful order. . .
All I'm asking for is the number stamped on the radiator shroud (which should be the same as the one on your compliance plate if you have one) and the number that is stamped on the bulkhead behind the clutch master cylinder (or sometimes on the scuttle panel gutter above the wiper motor). I do not need engine numbers, rego numbers, names or addresses. . .
If you're worried about me doing nasty things with the numbers (I cant think what I would do but I'm sure some people have a better imagination than me. . .), then feel free NOT to send me the details of your car. . . :D Easy!
If you'd rather not have the info on the forum, just pm me with your cars details instead. . .
Thanks for the anticipated help. . .
PostPosted: Tue Feb 27, 2007 3:12 pm
No?
Fair enough. :wink:
PostPosted: Tue Feb 27, 2007 3:15 pm
Soz mate, I forgot I was so busy. I'll give you mine. Stby for a PM
PostPosted: Tue Feb 27, 2007 3:50 pm
Brilliant - thanks Mick!
PostPosted: Tue Feb 27, 2007 5:15 pm
How many does that make it then?
PostPosted: Tue Feb 27, 2007 5:35 pm
Yours makes seven - although one of those is known to have been re-shelled (and the original chassis number 'fell off' the S shell onto the replacement somehow. . .).
Suprising thing is, I picked up 5 sets of numbers from Al Munday's MiniCentral in one day!!
That's a lot of genuine S's in one place at one time, these days. . .
What I have already covers a wide range of body numbers (from the 40's to 2200-ish) - but the more the better!
Users browsing this forum: No registered users and 422 guests
