tin brake/clutch master cylinders
https://www.ausmini.com/forums/viewtopic.php?f=2&t=28585
Author:  thomen [ Tue Feb 27, 2007 10:12 am ]
Post subject:  tin brake/clutch master cylinders
Hi Just wondering what the difference between the 2 was? ie can you buy a set of 2 "clutch master cylinders" and run the brakes with one?
thanks,
- tom
Author:  doogie [ Tue Feb 27, 2007 11:32 am ]
You need a brake master cylinder for the brakes & a clutch master cylinder for the clutch, if you mix them around neither will work.
Doogie
Author:  czerial [ Tue Feb 27, 2007 12:10 pm ]
the brake one has a different innards.
Author:  TheMiniMan [ Tue Feb 27, 2007 12:11 pm ]
The brake cyl has a slow return valve fitted inside, & you can fit that into a clutch cyl , then it will be a big diameter brake cyl, pedal will be harder & higher than normal & more pressure will need to be applied to the pedal for it to be as effective as the smaller (std) brake cyl.
the brake cyl is normally a .7" item
the clutch is best as a .75" diam
Author:  thomen [ Tue Feb 27, 2007 12:14 pm ]
awesome thanks so much guys!
posted a wanted for a tin brake master cylinder in the wanted section then!
Author:  czerial [ Tue Feb 27, 2007 12:17 pm ]
you can buy them new from mini spares in uk tom
Author:  thomen [ Tue Feb 27, 2007 12:19 pm ]
thanks chris!
if nothing pops up from the wanted ad ill look at getting some from there!
how's ye olde elmo going?
Author:  czerial [ Tue Feb 27, 2007 12:59 pm ]
the only prob with second hand ones, is that oncfe the metal tarnishes, they are
almost not possible to get them looking like new again, wehreas the new ones
come out lookeing great!
Elmos is reallly good thanks mate, but looking to move him out of home tho.
