Roof size difference between Clubbie and Roundie https://www.ausmini.com/forums/viewtopic.php?f=2&t=28592 |
Author: | birty [ Tue Feb 27, 2007 12:31 pm ] |
Post subject: | Roof size difference between Clubbie and Roundie |
Hi all, I would assume that the roof size (dimensions) between a Clubbie and Roundie is the same - is this correct. Just wondering about vinyl roof kits. Cheers, Rob. |
Author: | rampage101 [ Tue Feb 27, 2007 12:33 pm ] |
They are the same afaik. |
Author: | sports850 [ Tue Feb 27, 2007 12:34 pm ] |
Same all the way through production , right through to rovers . Only difference was Pommy shells had half moon shaped cutouts for drainage in the corner's and Aussie ones had two small holes drilled . |
Author: | Anto [ Tue Feb 27, 2007 2:20 pm ] |
I knew a bloke here in Canberra that welded an 850 roof to his 78 Clubby. Welded it through the pillars so the front and rear windscreen were a touch hard to get in. Would never have guessed if he hadn't pointed it out! |
Author: | birty [ Tue Feb 27, 2007 4:01 pm ] |
Many thanks to all for the confirmation. |
Author: | 9YaTaH [ Tue Feb 27, 2007 6:25 pm ] |
Post subject: | 1970s |
Vinyl roof Rob?? very 1970s ![]() ![]() |
Author: | birty [ Wed Feb 28, 2007 6:26 am ] |
Yep - a possibility - just keeping my options open at this point ![]() |
Author: | jbeenz [ Wed Feb 28, 2007 3:38 pm ] |
Have you found a vinyl roof kit? im after one! in white ![]() |
Author: | kenworthkid1271 [ Thu Mar 01, 2007 2:45 am ] |
Thanks for asking that question of the roofs sizes being the same Rob, it saves me posting it now. I'm thinking about ditching the Britax sunroof in my GT & was looking at using a roof from a 1968 Deluxe. Cheers Jeff. ![]() |
Author: | birty [ Thu Mar 01, 2007 7:54 am ] |
Chequered roof kit with 7 year vinyl for $67.00 from ebay. I have a sunroof so will have to do some cutting around it but should be no worries. |
Author: | Gadgets mini [ Thu Mar 01, 2007 8:00 am ] |
birty wrote: Chequered roof kit with 7 year vinyl for $67.00 from ebay. I have a sunroof so will have to do some cutting around it but should be no worries.
pics please when finished ![]() |
Author: | birty [ Thu Mar 01, 2007 12:54 pm ] |
Coming in from the UK via slow mail. Then have to repaint my mini first (hopefully April) and then I'll get them on. Don't hold your breath waiting for pics ![]() Cheers, Rob. |
