It is currently Sat Jul 19, 2025 1:04 am
PostPosted: Mon Nov 15, 2004 12:51 pm
My engine currently has a 290 Scatter pattern cam, i'm just worried that it will not be a great road car the engine was orignaly designed to be a race engine.
I've heard a bit about the SW5 from swift tune in the UK, anyone had any expirence with these?
http://www.swiftune.co.uk/
65 DELUXE
69 DELUXE
MY MINI PICS: http://www.flickr.com/photos/morrie850/
PostPosted: Mon Nov 15, 2004 1:15 pm
I think you would find it a pig on the street, scatter or not...
Depends what you want.
SW5 is supposed to be nice and smooth but I doubt it's much good over 6000.
286 is as far as I would go unless it's for track, best street cam I've run is Russell Engineering's RE-13.
It kicks in around 2500-2700, but is quite smooth below that. Mine will pull from 1500 with a 45 Dellorto (36mm chokes), and with 1.5 rockers on it, is still hauling ass at 8000... not that I do that much!
PostPosted: Mon Nov 15, 2004 2:02 pm
I guess I want a nice quick daily driver thats good off the lights & on the highway & not lumpy as all F@#K.
Who Sells the Russel Enginering gear?
65 DELUXE
69 DELUXE
PostPosted: Mon Nov 15, 2004 2:33 pm
... Russel Engineering...? :wink:
PostPosted: Mon Nov 15, 2004 2:43 pm
Thats the one, wasn't sure if it was a brand name or just a business name.
It's $130 I send him up a stock one.
65 DELUXE
69 DELUXE
PostPosted: Mon Nov 15, 2004 5:59 pm
Make sure you check the cam timing with a degree wheel and dial gauge.
A 1098 I did up recently, which had a duplex chain kit was 10* out in timing, due to a keyway cut wrongly.
No fault of the cam- the stocker I took off it was retarded 10* too. :shock:
It's fine now- I've put a 10* offset key in it. :wink:
PostPosted: Mon Nov 15, 2004 9:11 pm
I have not read any of David Vizard's books in years. does he get into anti-reversion extractors to make wild cams more road usable? He went right into it with a B series in Car & Car Conversions many years ago and reckoned it was a good thing. I must buy his book and read it I suppose.
Chris
Everything I like is either
