It is currently Sat Aug 23, 2025 2:59 pm
PostPosted: Tue Feb 27, 2007 12:31 pm
Hi all,
I would assume that the roof size (dimensions) between a Clubbie and Roundie is the same - is this correct.
Just wondering about vinyl roof kits.
Rob.
Rob.
PostPosted: Tue Feb 27, 2007 12:33 pm
They are the same afaik.
PostPosted: Tue Feb 27, 2007 12:34 pm
Same all the way through production , right through to rovers . Only difference was Pommy shells had half moon shaped cutouts for drainage in the corner's and Aussie ones had two small holes drilled .
PostPosted: Tue Feb 27, 2007 2:20 pm
I knew a bloke here in Canberra that welded an 850 roof to his 78 Clubby. Welded it through the pillars so the front and rear windscreen were a touch hard to get in. Would never have guessed if he hadn't pointed it out!
PostPosted: Tue Feb 27, 2007 4:01 pm
Many thanks to all for the confirmation.
Rob.
 Post subject: 1970s
PostPosted: Tue Feb 27, 2007 6:25 pm
Vinyl roof Rob?? very 1970s :!: :D
PostPosted: Wed Feb 28, 2007 6:26 am
Yep - a possibility - just keeping my options open at this point :D
Rob.
PostPosted: Wed Feb 28, 2007 3:38 pm
Have you found a vinyl roof kit? im after one! in white :roll:
PostPosted: Thu Mar 01, 2007 2:45 am
Thanks for asking that question of the roofs sizes being the same Rob, it saves me posting it now.
I'm thinking about ditching the Britax sunroof in my GT & was looking at using a roof from a 1968 Deluxe.
Cheers Jeff. :)
5/72 Clubman GT - awaiting restoration...... & purchase of the missing parts to do so!!!!
PostPosted: Thu Mar 01, 2007 7:54 am
Chequered roof kit with 7 year vinyl for $67.00 from ebay. I have a sunroof so will have to do some cutting around it but should be no worries.
Rob.
PostPosted: Thu Mar 01, 2007 8:00 am
Resident Haemorrhoid
pics please when finished 8)
mtsmini wrote:
Tombo wrote:
PostPosted: Thu Mar 01, 2007 12:54 pm
Coming in from the UK via slow mail. Then have to repaint my mini first (hopefully April) and then I'll get them on.
Don't hold your breath waiting for pics :D
Rob.
Rob.
Users browsing this forum: Majestic-12 [Bot] and 227 guests
