How to Remove Clubman 1/4 Windows?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=28653
Author:  YoungMiniac [ Wed Feb 28, 2007 5:16 pm ]
Post subject:  How to Remove Clubman 1/4 Windows?
I need to remove 1/4 windows from my clubman so I can get painting, how the hell do they come out?
Cheers Ian
Author:  lil-ute [ Wed Feb 28, 2007 5:27 pm ]
use a cold chisel to knock the screw heads off if that dont work just smash the glass or you could paint over them
Author:  sports850 [ Wed Feb 28, 2007 5:30 pm ]
Really helpful Allan ....
Undo the two short bolts on the door proper (behind the door card , have a look and you'll see the ones I mean) , then the screws on the outer edge of the window frame . Wind the window down and pull the top of the quater window towards the rear of the door , then lift it out when you can . They are very easy really , only a problem if the screws at the top are rusted .
Author:  YoungMiniac [ Wed Feb 28, 2007 5:30 pm ]
I have unscrewed the screws, do I need big window out aswell?
Author:  sports850 [ Wed Feb 28, 2007 5:31 pm ]
How about the two bolts in the door ? You wind the window down to get the quater out then you can pull the main window out .
Author:  lil-ute [ Wed Feb 28, 2007 5:33 pm ]
i didnt know either but i do now
thanks ian
Author:  Clubbie74 [ Wed Feb 28, 2007 5:40 pm ]
I pulled mine out towards the inside of the window as I found this easier (Clubby) and a bit of a twist and wiggle motion as it came. Also use tape on the metalwork around the top of the window to save the paint.
Author:  YoungMiniac [ Wed Feb 28, 2007 7:02 pm ]
Thanks Ian I didn't realise it had two bolts it out now :D to start masking....
