It is currently Fri Aug 22, 2025 6:20 pm
PostPosted: Fri Mar 02, 2007 1:56 pm
Hey all, would morris 850 seats fit into a '74 clubman?? front and back seats...
Thanks in advance
PostPosted: Fri Mar 02, 2007 1:58 pm
Should do....?
Can't say that i have tried, but i don't see any reason why not.
PostPosted: Fri Mar 02, 2007 2:00 pm
Might wanna investigate the laws on that... 74 probably requires headrests - hence all 73/74 onwards have headrests in the seats.
Sure, lowbacks look ultra cool, but you may get busted for it if the policeman wants to be formal about it.
PostPosted: Fri Mar 02, 2007 2:01 pm
they will fit straight in, but.....
technically for a 1974 Clubman you need headrests (ADR law) and 850 seats certainly don't have them.
is it real strict?
PostPosted: Fri Mar 02, 2007 2:15 pm
may not pass rego inspection if it doesn't comply with ADR laws.
strict enough?
PostPosted: Fri Mar 02, 2007 2:19 pm
What are the 850 seats , you might be able to swap them with someone for good clubman seats ?
PostPosted: Fri Mar 02, 2007 2:23 pm
The clubman seats also have a clip to hold them to the rails bolted into the rear floor. Stops them tipping forwards in the event of a sudden stop/accident.
850 seats are rarer - should be able to swap for clubbie seats in even better condition.
PostPosted: Fri Mar 02, 2007 3:42 pm
i have some leyland seats, i would consider swapping for 850 seats.
PostPosted: Fri Mar 02, 2007 4:32 pm
It's only the real late Clubman seats that are different. Even then, they still have the holes with captive nuts in them to mount the old style seats! 8)
Users browsing this forum: No registered users and 297 guests
