Ok.... assembled 2 lots of brakes today. I started with 1 complete set of vented metro brakes and 1 complete set of standard 8.4" solid discs off a Rover/1275LS/moke. Here are my results.
This is what you get when you put the SOLID discs and Rover/1275LS/moke calipers onto the Metro turbo hubs....
Here is a list of what is used in this setup.
-pair of metro turbo hubs.
-pair of metro drive shaft ends (same as mini disc ones) with the tapered washer and nut
-pair of 8.4" standard rover/1275LS/moke calipers ( 2 pistons )
-pair of 8.4" solid disc rotors
-pair of rover mini drive flanges to suit the solid disc rotors
This is what you will need to buy and/or modify
-8x new high tensile bolts that hold the flange to the disc. (I believe they are 3/8" imperial)
-Ball joints may need to be replaced - later shafts do not fit mini arms.
-Mounting holes on the caliper need to be enlarged slightly (1 or 2 mm) to allow the metro hub mounting bolts to fit.
-Change the steering arms with ones that are currently on your mini.
-New flexable brake hoses
-Adjustable bottom suspension arms to correct the camber
-New split pins for driveshaft , and maybe for the pads too.
-New locking tabs for the steering arm bolts and caliper bolts
-Piston rebuild kit
This is what you get when you put the VENTED discs and 4 pot calipers onto the Rover/1275LS/moke hubs....
(picture stolen from Harley.... was better than mine)
-pair of rover/1275LS/moke hubs.
-pair of rover/1275LS/moke driveshafts to suit discs, with the tapered washer and nut
-pair of Metro Turbo 4 pot calipers
-pair of Metro Turbo 8.4" vented disc rotors
-pair of Metro Turbo drive flanges to suit the vented disc rotors (may need the 4 locating tabs machined off the face, depending on the wheel you use)
-Hose adapter kit and flexable brake hoses (4 pots have 2 brake lines per caliper which need to be linked to the one supply hose per side of the car)
-Piston rebuild kit
