It is currently Fri Aug 22, 2025 12:01 pm
PostPosted: Fri Mar 02, 2007 1:56 pm
Hey all, would morris 850 seats fit into a '74 clubman?? front and back seats...
Thanks in advance
PostPosted: Fri Mar 02, 2007 1:58 pm
Should do....?
Can't say that i have tried, but i don't see any reason why not.
PostPosted: Fri Mar 02, 2007 2:00 pm
Might wanna investigate the laws on that... 74 probably requires headrests - hence all 73/74 onwards have headrests in the seats.
Sure, lowbacks look ultra cool, but you may get busted for it if the policeman wants to be formal about it.
PostPosted: Fri Mar 02, 2007 2:01 pm
they will fit straight in, but.....
technically for a 1974 Clubman you need headrests (ADR law) and 850 seats certainly don't have them.
is it real strict?
PostPosted: Fri Mar 02, 2007 2:15 pm
may not pass rego inspection if it doesn't comply with ADR laws.
strict enough?
PostPosted: Fri Mar 02, 2007 2:19 pm
What are the 850 seats , you might be able to swap them with someone for good clubman seats ?
PostPosted: Fri Mar 02, 2007 2:23 pm
The clubman seats also have a clip to hold them to the rails bolted into the rear floor. Stops them tipping forwards in the event of a sudden stop/accident.
850 seats are rarer - should be able to swap for clubbie seats in even better condition.
PostPosted: Fri Mar 02, 2007 3:42 pm
i have some leyland seats, i would consider swapping for 850 seats.
PostPosted: Fri Mar 02, 2007 4:32 pm
It's only the real late Clubman seats that are different. Even then, they still have the holes with captive nuts in them to mount the old style seats! 8)
