It is currently Wed Aug 20, 2025 10:38 pm
 Post subject: shocking lol
PostPosted: Fri Mar 02, 2007 7:06 pm
would these be alright for my '66 deluxe wit hydro (obviously take the hydro out)
http://cgi.ebay.com.au/MINI-COOPER-GAZ- ... dZViewItem
do i need shocks too
http://cgi.ebay.com.au/MINI-SHOCKER-KIT ... dZViewItem
'94 Honda EG4 Civic. -Daily-
'95 Honda DC2 Integra
PostPosted: Sat Mar 03, 2007 1:13 am
I think you need rubber cone type top arms and trailing arms to make these fit.
I'd stick with the hydro, personally.
PostPosted: Sat Mar 03, 2007 6:20 am
There is no need to change the suspenion arms on a hydro mini to dry type . To fit coil overs to a hydro mini you will need to replace the rear stub axle with a dry suspension type. You also may need to enlarge/drill out the hole on the top front arms where the front bump stops are bolted to.The coil overs are shocks and springs.
