It is currently Wed Aug 20, 2025 10:45 pm
 Post subject: Mechanical Brake Switch
PostPosted: Sat Mar 03, 2007 11:57 am
My brain has turned to mush.
I have been doing lots of work on both cars over the last couple of days, so my ability to sort this out has left me in a haze of brake dust and oil fumes.
I cannot see how the brake pedal engages the mechanical brake switch. I must have one of them set up incorrectly.
Anybody have a desription or picture that can assist?
PostPosted: Sat Mar 03, 2007 12:01 pm
Isn't the brake light switch hydraulic?
PostPosted: Sat Mar 03, 2007 12:04 pm
nope mine is a electical switch that sits near the brake pedal
PostPosted: Sat Mar 03, 2007 12:27 pm
It's a normally closed switch, the pedal holds it open circuit so lights OFF. :wink:
PostPosted: Sat Mar 03, 2007 12:30 pm
Where does the pedal engage the switch. I can see no way for the pedal to contact the switch when the pedal is not engaged.
In other words I cant see for looking
PostPosted: Sat Mar 03, 2007 2:52 pm
If it's the Moke, most likely the bracket is bent on the pedal box. Bend the bracket down until the switch is depressede when the brake pedal is at rest.
Oh, and don't bother with a genuine one. A cheap universal one from super-crap etc fits fine.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Sat Mar 03, 2007 3:15 pm
I have a cheapie. The old one was never connected so I am flying a little blind. Ill give bending the bracket a go. Thanks
PostPosted: Sat Mar 03, 2007 4:19 pm
You want pedal to clear the switch before you hit brake pressure. Gives the guy up your clacker a little more braking time.... :lol:
PostPosted: Sat Mar 03, 2007 4:23 pm
nar no fun - he shouldnt be following that close :P
